HDMI 4x4 matrix repair help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-04-2013, 04:04 PM - Thread Starter
EpicVegas's Avatar
I have a monoprice 4x4 matrix that got the wrong power cable plugged into it and popped.
I quickly shut it off and waited awhile before I plugged the correct power supply into the unit.
All the lights light up solid blue but no switching our source selections work.
Any advice on what I can do or a repair shop that could fix it?
EpicVegas is offline
post #2 of 3 Old 01-05-2013, 09:32 AM - Thread Starter
EpicVegas's Avatar
Any ideas?
I would hate to just through this unit in the trash...
post #3 of 3 Old 01-07-2013, 09:33 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Bet it'l cost far more to fix if you can find some one to try then a new one.
Phil17108 is offline
Reply Home A/V Distribution
