How to move coax cable from floor to wall plate. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-07-2013, 04:02 PM - Thread Starter
austin12block's Avatar
To begin I am in a bedroom with wood floor then thick carpeting. The walls are drywall. There is also a floor board around the room. I have a coax cable coming up through the floor in the center (not a corner). I will get a wall plate and mount without a box but with inserts. That is how I want too...no giant holes! Under the room is my garage with a dry wall ceiling. In the corner is the main meeting place of coaxials. It goes to the cieling where a 6" by 6" square was cut away. It goes up to the bedroom there. The hole isn't directly below where it comes up though. About one foot off. Up inside is a place I prefer not to stick my hand in too much. It is full of insulation. I can get a cutter and new tips if needed but what is the best way. Pull old cable out? Will I run into studs between the levels?
austin12block is offline
post #2 of 3 Old 01-07-2013, 06:23 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You want to re-route the coax into the wall, to a wall plate?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 3 Old 01-07-2013, 06:42 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Does your carpet extend below the baseboard? There is often a gap there large enough for a cable, so that you could run the cable to your cabinet/stand without being seen.
If you're set on adding a wall plate, take a close look into that 6" ceiling hole, with a flashlight. Cut a single gang hole in the TV room drywall, and drill with a long bit (10-18") down through the bottom plate. You may need to enlarge that 6" ceiling drywall hole to find it.
Neurorad is offline
Reply Home A/V Distribution
