New home prewire - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-10-2013, 06:12 PM - Thread Starter
Decelerate's Avatar
Quoted: 12 Post(s)
I am trying to figure out how to prewire my home while keeping my options open for any control system.
The video distribution seems straightforward. Just 4 cat6 to each tv location.
The audio distribution is confusing me a bit due to the various interfaces for in wall control.
Standard 16/4 to each speaker location is simple enough.
But what do I do for the future keypad/touch screen locations?
I am thinking of doing a cat5e to each future touchscreen location.
I am also planning on putting in cresnet to each future keypad location.
But what cables would I need if I opt to do Rti or Nuvo or any other system for that matter? Some type of power seems reasonable, but I really don't know what else...
Any help is greatly appreciated.
EDIT: I am working with a local integrator, but wanted opinions from the forums.
Also, what would be a reasonable pre wiring budget for a 5k sqft home (10-12 zones audio, 4 video zones)?
Decelerate is offline
post #2 of 8 Old 01-10-2013, 06:39 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 782
And at least one, preferably two RG6 runs.
Cat5e to the keypad location is the standard. Loop the 16/4 through that location as well to keep all the future options open.
Cat5e. Decent assumption can be made that future controls / keypads / touchscreens will utilize cat5e, and very likely actual Ethernet and PoE.
Will depend a lot on your location, what the builder already includes as their standard wiring, and how the work will be done. In my build for a similar scope, the builder included 32 wire drops (8 locations of 2xRG6+cat5e and 8 more cat5e) and six audio zones by default. I added 60 additional wire drops and 3 audio zones. I provided the extra wire (Monoprice - I probably spent $300) and would do the extra terminations. The subcontractor gave me a price of $700 for just the additional labor, I don't know what he charged the builder for the first 32 runs + audio zones.
Didn't seem like it that day, but after seeing how much work it would have been for me to really do it myself (I'm experienced, so it wasn't a total shock), I got off easy. I've seen pre-wire quotes in the $2000-2500 range when starting from scratch (materials+labor). That doesn't seem out of line at all.
Jeff
jautor is offline
post #3 of 8 Old 01-10-2013, 06:59 PM - Thread Starter
Decelerate's Avatar
Quoted: 12 Post(s)
I was under the impression that basic button keypads from Rti require DC power.
post #4 of 8 Old 01-10-2013, 09:39 PM
jautor's Avatar
Liked: 782
They do. And they connect to the control unit using an RJ45-terminated cat5e wire.
jautor is offline
post #5 of 8 Old 01-11-2013, 05:24 AM - Thread Starter
Decelerate's Avatar
Quoted: 12 Post(s)
So are you saying I can get away with just running one cat5e to power the keypad?
Or do I need some type of power cord.
post #6 of 8 Old 01-11-2013, 01:48 PM
jautor's Avatar
Liked: 782
If you look at the RTI control unit which is what powers / controls the keypad, you'll see they use an RJ45 connector (and therefore cat5e) as the power and signal connection.
So no, no separate power cord, just a cat5e cable.
Jeff
jautor is offline
post #7 of 8 Old 01-11-2013, 06:39 PM - Thread Starter
Decelerate's Avatar
Quoted: 12 Post(s)
Great that simplifies things a bit. Thanks.
So I think I will be covered for any future keypad or touchscreen by using a cat5e and cresnet.
post #8 of 8 Old 01-11-2013, 09:16 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Run this by the installer, or his designer. Crescat, I think, includes a pair of 18 awg conductors for power.
The Crestron designer should put his eyes on the final plans, before any cables are run, if Crestron is a consideration.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home A/V Distribution
