WHA Budget System Advice Much Needed!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-11-2013, 09:29 AM - Thread Starter
WHA Beginner's Avatar
I'm currently in the throws of renovating my house and have run speaker cables to all of the priniciple downstairs rooms (3). I'd like to have a single source system to be controlled from an ipad/iphone.
I'm not an audiophile so I'd like to keep the costs as low as possible but would just like to be able to choose audio from itunes and select which room(s) to play it in. If I got an AM/FM tuner in there too it would be great but it's not a necesity.
Any suggestions for a cheap single source, three zone, Ipad controlled system?
WHA Beginner is offline
post #2 of 5 Old 01-11-2013, 09:58 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Sonos Connect:Amp and an impedance-matching speaker selector (RadioShack has a 3-pair selector for <$50).
(another non-audiophile! wink.gif Are there no audiophiles on this board????)
jautor is offline
post #3 of 5 Old 01-11-2013, 10:09 AM - Thread Starter
ok will have a read up on that system then!!
post #4 of 5 Old 01-11-2013, 10:16 AM
Gramin's Avatar
Only you, Jeff.
And Jeff's suggestion for Sonos is your best solution. And if you ever want to expand, Sonos can easily handle that.
Gramin is offline
post #5 of 5 Old 01-11-2013, 10:22 AM
jautor's Avatar
Liked: 777
Originally Posted by Gramin View Post
Only you, Jeff.
I can't be an audiophile. My speaker wires are touching the ground, and cost less than the speakers themselves... wink.gif
jautor is offline
Reply Home A/V Distribution
