Russound ABUS KP2 power but no sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-18-2013, 08:53 AM - Thread Starter
ibrettferguson's Avatar
Have a basic single source, 4 room setup. (Hd4 + 4 kp2 keypads). And 3 of the 4 work.
The one that doesn't work has power (via indicator light). Is set to single source. But doesn't appear to power on.
6 year old system in a pre-wired home. Just stopped working for no apparent reason.
Thanks a bunch for your help!
ibrettferguson is offline
post #2 of 2 Old 01-18-2013, 09:52 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Swap the keypads or swap the wiring at the hub to see if it's the keypad or the hub. These pieces show up on eBay often...
Jeff
jautor is online now
Reply Home A/V Distribution
