Multi-room audio system with integrated intercom - AVS Forum | Home Theater Discussions And Reviews
Old 01-18-2013, 01:45 PM - Thread Starter
Fenyushin's Avatar
Can you advice me model of multi-room audio system with integrated intercom. I have pre-wired house with CAT 5 cable to keypad panel and separate audio cable to ceil speakers.
In general I like Russound systems + ComPoint, but as far as I understand 2 CAT5 wires are required for this system installation (first for multiroom audio control panel, second for ComPoint).
Thank you in advance for advice
Eugene
Fenyushin is offline
Old 02-28-2013, 09:36 AM
skinsfanin1979's Avatar
Have you looked into HTD's Lync system? In my research it was one that combined multi-room audio and intercom directly through the keypad:
http://www.htd.com/Products/Lync
However, I have to ask nowadays are intercoms even necessary unless you live in a mansion, which in case kudos to you! smile.gif
skinsfanin1979 is offline
