UNsnapping Leviton Quickport? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-19-2013, 12:24 PM - Thread Starter
DanRadmacher's Avatar
Stupid question, and I don't know the best place to put it, but I have four Quickports in a plate and now realize I should have gone with a six-port plate to make room for the cable connection. The problem? I can't figure out how to get the $*#& things out of the plate. Once they're in, are they in for good, or is there a simple way to release them I haven't figured out?
DanRadmacher is offline
post #2 of 2 Old 01-19-2013, 02:48 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Small flat screwdriver blade from the back side to compress and release the clip that holds the keystone in place. If you look at one of the bare keystones, you'll see the clip and where to lever...
jautor is online now
Reply Home A/V Distribution
