Usage of Cat5/Cat6 vs Coax for OTA antenna and / or satellite internet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 01-21-2013, 02:58 PM - Thread Starter
drandersoninc's Avatar
Hi all,
I've been researching this as best I can, and I have not been able to determine a definitive answer unfortunately. I am in the process of designing a new house and looking to satisfy my cabling needs as uniformly and as cost effective as possible. This will be in a remote location devoid of any incoming 'hard lines' (like cable or phone). As the rest of the house will have CAT6 dropped in every room for my LAN anyway, I was looking to attempt to use CAT6 everywhere / as much as possible to keep things more uniform. To that end I need to bring the following signals in, which are normally over RG6 coax:
1) Satellite internet (say Wildblue or HughesNet)
2) OTA antenna for TV
3) Wilson cellular signal amplifier
For #1 and #2 I have multiple drop points in the house (at least 4 widely separated locations), #3 would be a single drop.
From reading there are those that say CAT6 cannot be used:
Coax over CAT5
OTA through CAT5
while other places indicate it should be / is possible using baluns or a setup from this site: Lynx
If I'm going to spend more or signifcantly increase my complexity I can go the Coax route, I was simply trying to stay as consistent as possible with an eye on budget.
Thanks for the help!
drandersoninc is offline
post #2 of 33 Old 01-21-2013, 03:57 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
You'll want to run at least one RG6 coax to every potential display location as well as cat6 (or cat5e), and bring at least one of each from your wiring closet to the outside of the house to allow connection to whatever provider(s) you'll have now, or in the future.
And yes, while you should run lots of cat6 / cat5e wire, there are things that were simply not designed to use it. Meaning OTA / CATV / Satellite feeds. While you may not utilize it immediately or in your current plan, you want to be able to utilize any service that becomes available... Which means having both types of cabling in the walls.
Adding one spool of RG6 is not going to break your budget, nor will it really increase the complexity of the system. What could do both, though, is having to work around NOT having it when the equipment / service provider you choose later requires it...
Jeff
egnlsn likes this.
jautor is online now
post #3 of 33 Old 01-21-2013, 04:11 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
That's a MINIMUM of 1 CAT5e and 1 Series 6 coax to each location. A much better plan would be to have 2 coax and a minimum of 3 CAT5e to each location -- 4 or 5 would be better. 1 for voice, 1 for network, and 1 for HDTV distribution. With the HD distribution, 3 pairs of the cable are utilized for the video while the 4th pair is for digital audio. If analog audio (L+R) is going to be run to a location, a separate cable is needed for that (1 pair for each channel of audio). With additional pairs of copper, you have what you need for i.r. distribution and pretty much anything you may want to do down the road..
CIAO!
Ed N.
egnlsn is offline
post #4 of 33 Old 01-21-2013, 04:17 PM
gregzoll's Avatar
Liked: 33
It is already coming down to that wired is becoming a thing of the past. Trendnet just announced last week, a 1.3gbps Wireless Router. It will still be nice to have at least one wired connection to each location that you have coax, but personally I would go one coax, two Cat-6 to each plate. Any place that you know that you may have multiple pieces of equipment, you can get away with at least 6 Cat-6 drops, vs. having a switch in that location. The choice is yours.
But with Wireless Technology finally getting into a place that wired is becoming ancient technology, you may find that in five years you will not be using very many drops. We pull out six drops in our place, due to never used them, and the devices that were on them, finally went online to our Wireless network.
Even with providers going with wireless type receivers, we are finding that they are looking at the future, not the past, when it comes to connection to the gateway in the structure.
gregzoll is offline
post #5 of 33 Old 01-21-2013, 08:38 PM
jautor's Avatar
Liked: 777
Not buying it... Wired has a lot of advantages over wireless, regardless of the speed of the connection. Security, power delivery, reliability, etc.
Now, that said, I do agree that we'll probably be using less wire in the future than we do now, but that's more due to the increasing use of actual 'networking' instead of the analog, proprietary, point-to-point uses that consume a lot of wire (talking cat5e here mostly) today. So I hesitate to recommend the 4-6+ cat5e runs to display locations that just recently was not at all a ridiculous number. I'd trade *some* wire to a LOT of locations over a lot of wire to too few locations. But - category cable is so cheap, more wire to more locations is still the right answer...
Jeff
post #6 of 33 Old 01-22-2013, 06:33 AM - Thread Starter
Very helpful insights, thanks to all.
Another question from someone new to this area: I've seen / read about the Coax to Catx and vice versa baluns, do they only work in some instances? Something related to the ohms of the signal being carried? So in specific, why wouldn't the OTA or satellite signals work with that architecture (balun adapters)?
And in relation to Coax, instead of running 2 RG6 would I be better off running a single RG11 and pushing 2 signals through one cable (if needed)? My max runs would be approx 80 ft or so.
post #7 of 33 Old 01-22-2013, 07:05 AM
SAM64's Avatar
Liked: 78
They're for baseband signals, not RF..
how do you plan to do that?
SAM64 is offline
post #8 of 33 Old 01-22-2013, 07:16 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
I would be hesitant of the cat5/6 for every thing. What about the satellite vendors like Direct and Dish do the installers work with the cat cable and does the vendor support it. I do not know about Dish but Direct has a networking system over coax called deca that needs a RG6 solid copper cable. It does not cost much more then the copper clad, and at $90 bucks for a 1000 feet at Satpro.tv you can have it every where you can think of. If I were building a new place I would do a home run from a central location inside with 3 cat6 and 3 RG6 solid with 4 RG6's to the roof. With cat6 around $110 for a 1000 feet it would not be a budget consideration for me.
Phil17108 is offline
post #9 of 33 Old 01-22-2013, 07:36 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
No on the second part: the purpose for 2 coaxes is so that they may be used for different applications; such as 1 carrying a satellite service and the other distributing OTA. There are people who subscribe to multiple services such as DirecTV, Dish Network, and CATV. Something like that would need a separate coax for each service. And, if you wanted to throw OTA into the mix, it would need its own coax. You could have Dish Network and use the 2nd coax to get the 2nd output (of the DVR) to another room.
On the first question: Those setups work only in some circumstances (baseband video). They can't be used for CATV or OTA or satellite distribution.
CIAO!
Ed N.
egnlsn is offline
post #10 of 33 Old 01-22-2013, 07:46 AM - Thread Starter
My thought (solely from reading) was a signal combiner as described here. Perhaps that was misguided if you are questioning it.
However from the general feedback I'm getting on the thread it appears that:
1) It's better to have (in general) a separate coax line for everything that needs it
2) To keep the coax runs and not attempt any CAT6 conversion for them. Run CAT6 separate for the computer network as needed
3) Solid core RG6 should be able to handle my expected 80' runs without an issue
So unless the above summary is off I think that has answered my question(s). Thanks again for everyone's help.
post #11 of 33 Old 01-22-2013, 08:24 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
If anything uses frequencies used by another service, they cannot be combined. CATV utilizes 5-750 (or 860)MHz, while OTA (including f.m.) occupies 88-806MHz. Both satellite services occupy the same bandwidths. A portion of DirecTV is in the CATV bandwidth, and so on.
If frequencies do not overlap at all, you can combine them.
CIAO!
Ed N.
egnlsn is offline
post #12 of 33 Old 02-05-2013, 01:11 AM
archbid's Avatar
I may be missing the point, but have you considered something like HDHomeRun for carrying the signal? It is not a signal converter, it is a tuner, but you plug in coax from cable or OTA, then plug it into your network, and you get two IP-addressable tuners that work with Windows MCE and EyeTv. The MCE integration is incredibly slick.
Just a thought.
archbid is offline
post #13 of 33 Old 02-06-2013, 06:36 AM - Thread Starter
That is an interesting idea, and along the lines of what I may have been looking for. I actually contacted the company to see how it could fit into my current plan below:
In their response they essentially indicated that a future release this year would support connection to DLNA TVs / devices:
"The current model of HDHomeRun Dual will not do DLNA. The one that is coming out later this year will do DLNA.
The HDHomeRun would connect to the incoming coax from the antenna, and then to one of the ethernet ports on your router. Your PCs and DLNA devices would then be able to access it, along with the internet, each other, etc.."
If this is the case, then my cabling appear that it could possibly be simplified to piggback on the Cat6 wiring that will already be going to the target devices. In the drawing that would mean that all the red Coax lines from the OTA antenna splitter could go away, the splitter replaced with this device, and a Cat6 line simply run to the router to its left. That has a good potential.
I know there has been a lot of recommendations for running Coax lines regardless, but I do see the benefit of consolidating to primariliy Cat6 lines. I don't see any other signals I need to bring in in the future that would warrant Coax lines and would like some thoughts from folks on how having extra coax lines available have made a difference for them? And if that would make sense for my situation.
post #14 of 33 Old 02-06-2013, 12:44 PM
jautor's Avatar
Liked: 777
I'm not going to start yet another debate on the topic. But you're mixing the system design with the pre-wiring. They are separate topics. Wire for flexibility, make sure you have your options covered. Equipment will come, go and change. You only get one chance to pre-wire.
post #15 of 33 Old 02-06-2013, 01:12 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
+1
Your needs/wants may change in the future and you may find a need for coax. Regardless of current intentions, you may sell the house in a few years, and there being no coaxial cable in rooms is a big detriment. Not too many people want to buy a house if they are unable to put a TV in the bedroom.
CIAO!
Ed N.
egnlsn is offline
post #16 of 33 Old 02-06-2013, 02:36 PM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
Why do some people think you don't need coax?
Why do some people think wireless is better? It will never be, radio waves sometimes have a mind of their own.
If I was doing a new home, I would have all the bases covered. Don't be a cheapie.
My Home:
Cat 3, 2 pair in all rooms for the phones. (Hate cell phone audio)
Cat 5E, multiple connections in all rooms.
RG-6, 2 cables in all rooms.
If your building a new home, don't skimp on the wiring and be sorry later.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #17 of 33 Old 02-06-2013, 03:33 PM - Thread Starter
.... Don't be a cheapie.
From the responses I'm getting (and they are appreciated, thanks) I think there may be a disconnect on my rationale for this. Cost is certainly a consideration, but it's not the only consideration. I do understand the difference between pre-wiring and design and the differences between them. And I don't even necessarily hate Coax as it may seem to be the case.... smile.gif
My intent at this point is not to debate the need to provide enough pre-wire options at my 'targets' in the house, adding additional drops at each location for future flexibility makes sense and my intent would be to do so regardless. But what I am debating is why to run Coax in addition to Cat6, if I can accomplish my signal connectivity needs with just Cat6. So far it appears my internet and OTA needs can be sent over Cat6, phone already goes over Cat6, so what else would I need Coax for going forward?
And I understand the argument can be said that 'you never know' and there is certainly truth to that, but it seems that Cat(x) cabling is the up and coming standard for being able to transfer a number of types of signals (including those 'normally' done over Coax), has a lower comparitive cost for good quality, and less signal attenuation / degredation over distances compared to Coax. With these things in mind it seems like the more favored standard now would be Cat(x) cabling just as Coax was a couple decades ago...
But again, the decision will ultimately be mine and I appreciate everyone's thoughts. Those were just my considerations at this point and why I was asking followup questions.
post #18 of 33 Old 02-06-2013, 04:05 PM
jautor's Avatar
Liked: 777
The only issue is "I may run wire I'll never end up using". That's cost. That's all.
I thought it had been made clear that you cannot run OTA over cat5e / cat6. Same with satellite services (TV or Sat Radio) or other broadband applications. That is, they will require the bandwidth of an RG6 link between the antenna and the set-top box / receiver. *IF* you place all of your reception / decode equipment at a central location and distribute HDMI or TCP/IP from there to every display location without exception, then yes, you can probably do fine without coax.
They are not interchangeable. And again, nearly 100% of new homes built today have a coax infrastructure as well as cat(x). Future usage will with high probability steer towards cat5e solutions, but there are plenty of use cases where coax is either the only solution or a cheaper solution. If you lock yourself out of one or the other, you may restrict your options.
Jeff
post #19 of 33 Old 02-06-2013, 04:08 PM
fedders's Avatar
Coax is needed for certain types of applications that cannot be met by category cables. The bandwidth of coax cannot be replicated by category cables, not even using all 4 pairs. You will need coax for OTA, satellite, and cable TV distribution (at least to the converter box). It will be that way for the foreseeable future. My advice would be to run a minimum of at least 1 coax to each location where you would have the possibility of installing a television. I'd then run a minimum of 2 Cat 5e/6 cables to each of those locations as well. Places where you might have what would be described as a Home Theater or Media Hub - double the wiring, at least.
Your coax construction should be at least 60% AL braid with a 18 AWG BC center conductor for the Sat applications (voltage to the dish). Ideally, use true quad-shield with 2 foils and 60%/40% braid as it is only marginally more expensive than dual-shield. If you want to go all-out, look for serial digial coax with BC center conductor, foil, and 95% TC braid. This is more expensive, but the best resi coax that you can install with great resistance for both the center conductor and shield.
You can go out of your way and try to force category cables to meet your needs, but at the end of the day you will regret not having the old stand-by in your wall.
Carl (wire expert)
egnlsn likes this.
Carl Fedders
fedders is online now
post #20 of 33 Old 02-06-2013, 04:18 PM - Thread Starter
Jeff
Indeed you had. However the HDHomeRun offering archbid discussed in his post allows just that, running OTA over cat6 vs Coax. It was an option I was not aware of, and I'm assuming others were in the same boat which is why I explored it further.
Jeff
That may be true at a technical level that I certainly don't understand nearly as well as most on this forum, however it appears there are multiple instances where a normal 'coax' signal can go across Cat(x) lines. One example is the HDHomeRun handling OTA antenna signals above. Another is my Verizon FIOS where the optical cable doesn't turn into Coax at my house wall per the norm, but directly into Cat6 at the house boundary. Another is satellite internet that comes in via Coax from the dish but is distributed further at the modem via Cat(x). It requires hardware in those cases to make it happen, but it appears it can happen now and to an even greater degree in the future.
Jeff
Fair statement, I was just trying to quantify what my potential scope 'gap' of future needs that could not be met by Cat(x) is all...
post #21 of 33 Old 02-06-2013, 04:24 PM - Thread Starter
fedders - Thanks for your inputs, I'll jot those down in my notes.
All, thanks again for all the help. I don't want this to degenerate into further conversations on Coax vs Cat(x) in a manner not helpful to others referencing this in the future. With all this information I believe I can now come up with a good game plan and again appreciate all the help. Thanks again, my question is answered.
post #22 of 33 Old 02-06-2013, 04:45 PM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
drandersonic,
Just use your head and do what you think is right. It's your home and you have to live with your choices. I posted my opinions and what I did to my home I am totally satisfied with and no regrets.
post #23 of 33 Old 08-26-2014, 04:30 PM
geronemo3's Avatar
Quoted: 32 Post(s)
Guys I am planning on moving into a new house.
Most of my stuff is on HDD and I play it wireless and wired. Now I am trying to get wired connection in every room as wireless sometimes stutters. For playing movies and TV shows mostly mkv format what is better cat5 vs cat5e or cat6?
geronemo3 is offline
post #24 of 33 Old 08-27-2014, 04:05 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
Cat5/5e has plenty enough bandwidth to handle an MKV file streaming out.
SMHarman is offline
post #25 of 33 Old 08-27-2014, 05:08 PM
BiggAW's Avatar
Quoted: 491 Post(s)
Liked: 119
There's an extreme disconnect here. Jauntor is spot on, and knows this stuff inside and out.
It would be completely idiotic to wire a house without RG-6. RG-6 is the standard, so everything video is, and will continue to be, designed around RG-6. OTA requires RG-6, satellite requires RG-6, cable requires RG-6. Sure, there are ways to move tuners around, but they may or may not exist in the future. Coax is the common denominator that everyone has, so you want to be like everyone else in that regard. Most houses do not have CAT-5 or better cable, so even networking for cable and FIOS is run through coax (although that can be run via Ethernet instead). However, FIOS, as a QAM-based TV system, requires coax.
Coax signals cannot go across CAT-X cable, and will never be able to. The RF signals and a stream that is derived by de-modulating an RF signal are two totally different things entirely, as some systems require the de-modulation to happen at the point of end use, or require networking over coax.
drandersoninc, if you want to be super cheap, run one RG-6 to each room and call it a day. You will be like most other houses in the US that have RG-6 and a bunch of useless phone wire that's often daisy-chained and/or low-spec (CAT-3 or worse), and thus is of no use for networking. If you want to do it right, then you add the CAT cable. A minimal setup would be 1 RG and 1CAT per room, so that you have service from your TV provider, and gigabit ethernet. Then from there, you could add more RG or CAT cables. The ideal but not overbuilt setup these days is probably 2 and 2 RG and CAT. That could theoretically accommodate gigabit ethernet, HDBaseT, OTA, and either cable or satellite.
Using "satellite-compatible" RG-6 is probably a good idea, although DirecTV installs on all sorts of crap, and it works fine. The SWiM/ DECA system is pretty robust, and will work in practice over any type of RG-6.
BiggAW is offline
post #26 of 33 Old 08-28-2014, 01:23 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
Jautor and BiggAW make some good points.
I just ran my prewire and the insulation and dry wall is now starting to cover it up hurray.
For each TV point (and all were within 50ft of the home run location) I ran 1 Cat 6S (premade), one HDMI (unpowered), one RG6 and two CAT5e. I decided that was a good compromise between cost and complexity. If I can get an HDMI signal from the closet to the TV I've saved $$ on baluns and I have a CAT5e to run the IR repeater for the TV commands on (if only CEC was more reliable).
In one or two corners of most rooms I ran another pair of CAT5e cables.
I ran a RG6 to a couple of corners so I can put an active sub in either of those locations.
I ran C5e to a few ceiling locations for potential use for (WiFi APs, Cameras etc)
I ran a few solo C5e to some wall locations to be left behind the wall for things like touch screens or other devices that I might want to put in the wall later
I ran solo C5e to where the appliances are. I can use it to attach waterbugs or other monitoring.
I ran 14/4 to any room I thought I might want to put speakers in
I ran 14/4 and 14/2 to the speaker points for 7.2.4 speakers.
From the outside wall to the closet I ran two RG6, one for CATV one for a Roof Aerial. I also ran two C5e to here as well (one of these may actually end up being a thermostat control for central air)
These are some ideas of what you might need. Buy 2 boxes of C5e so when you pull one you can pull 2 at the same time. It makes pulling cable easier. For example the bundle to the TV, all 5 cables was pulled in one pull as they were all on their own drums. Makes it much quicker. At one point I was pulling 11 cables in one hit through the main path and then redirecting at the far end.
Good Luck
SMHarman is offline
post #27 of 33 Old 08-28-2014, 03:40 PM
BiggAW's Avatar
Quoted: 491 Post(s)
Liked: 119
Good Luck
WOW. That is a thorough job. I would argue that it's pointless to wire for appliances and thermostats and the like, as they are all going to be Wifi to go in to existing buildings, but I guess if you're pulling the cable yourself, there isn't much harm in running a few extra lines here and there. The CAT cable for cameras and Wifi APs is a good idea. What about coax to the closet for satellite?
BiggAW is offline
post #28 of 33 Old 08-28-2014, 04:09 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
The Cat would be the control wire from the HVAC Compressor to the thermostat. The thermostat is then wifi or zigbee to the HA system.
The Cat to appliances is to put Waterbug Water sensors in. http://www.amazon.com/Winland-Electr.../dp/B000BKQ75G These can then be connected to a NO connection on my HA system for monitoring.
The Coax used was http://www.monoprice.com/Product?c_i...seq=1&format=2 anyone need 500ft, I got leftovers! Was cheaper to buy 1000ft and use what I needed. That roll weighs a ton compared to 1000ft of CAT. This is CATV or Sat capable, I can't see a situation where I or any future owner would need Roof, Sat and CATV at the same time (well now you mention it, maybe you are using the roof for FM, the CATV for Internet and SAT for TV!) so only two cables were run. There is an access pannel in the external wall where these cables come in under the window so if someone went Sat not CATV, you could run the cable in there and terminate to one of the two cables).
SMHarman is offline
post #29 of 33 Old 08-28-2014, 05:59 PM
BiggAW's Avatar
Quoted: 491 Post(s)
Liked: 119
Interesting. Sounds like you're pretty serious about the HA stuff. Does the CAT-5 replace regular thermostat wire then? Wifi thermostats are something I'd like to put in when I buy a house. Would be really nice to turn the A/C on and cool the house down before I arrive so that it's not 90 degrees when I walk in the door.
I guess if you wanted SAT, CATV, and FM, you could always run another RG wire.
What is the consensus these days on QS RG-6 cable? I've heard it's the best, but then I've also heard it's pointless in an all-digital world?
BiggAW is offline
post #30 of 33 Old 08-28-2014, 08:33 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
Yes this apartment will be pretty serious about HA. It will have a Control4 brain at the center with many lighting loads on a Control4 lighting panel (low and high voltage). 4 zones of audio and a family room with 7.1 for now but a pre wire for 7.2.4. To keep my neighbors happy that .2 will never happen it just gives me two locations to site the sub. Lighting, WHA and Family room AV will be on the Control4 system.
Regular thermostat wire is a 20ish gauge multistrand wire. As such you can substiture in Cat in a pinch. This is a last minute consideration for running apartment central air instead of window units, so I and the HVAC guy were looking at what was there and what is absolutely necessary at rough in to mean wou could upgrade to central air with minimum of fuss. The C5 cable will substitute and mean I am not needing to run a thermostat wire tomorrow.
I could run another RG but these will be behind drywall / baseboard etc so not likely. I use TuneIn for FM radio now (native to Control4 HA) or you could use I Heart Radio (on say a Sonos) so the need for an FM RG is diminished, if picking up OTA transmissions then it would share the OTA transmitter RG anyways.
I had no plans on running RG cable until this forum highlighted the error of my ways. I was all - well the TV equipment will be centralized and not under the TVs and I could always put a Roku and or a Tivo Mini behind each TV with a C5 cable attached to it so what is the point of RG6 then, like you pointed out before, why be weird. The next person living in this house may be grateful that RG6 is distributed in the wall to both bedrooms and the living room, so I ran it. Especially when I needed some for my Subwoofer Cables and buying the 1000ft was not a great deal more money than the 150ft I needed for the subs.
SMHarman is offline
Reply Home A/V Distribution
Cat5 Rack 1u
