Help with outdoor speaker installation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-21-2013, 03:31 PM - Thread Starter
Johninperth's Avatar
Hi guys
My current setup consists of a yamaha RX-A1020 with 7.1, then I have two outdoor speakers connected to a small Panasonic stereo. What I would like to do is have the outdoor speakers connected via zone 2 on the Yammy. The problem is I have a two storey house with concrete slab in between levels 1-2, so I'm unsure on how to run the cable from the amp to outside.
Is there any wireless speakers that I could connect to the zone 2 on the amp?
Any help is appreciated
Cheers
Johninperth is offline
post #2 of 5 Old 01-21-2013, 07:43 PM
jautor's Avatar
Quoted: 1225 Post(s)
Liked: 787
There are wireless audio send/receive units - but what are you trying to get from your AVR? Radio, set-top box output, music library? Take a look at using a Sonos unit for the outdoor speakers instead - you'd get control of it from a wireless device as well...
jautor is offline
post #3 of 5 Old 01-21-2013, 10:12 PM - Thread Starter
I want the radio, cd, iPod etc to play outside. Isn't the sonos units standalone?
post #4 of 5 Old 01-21-2013, 10:27 PM
jautor's Avatar
Liked: 787
No, the Connect unit attaches to any stereo receiver. Although a Sonos Connect:amp unit might be a better overall solution...
But for wireless connections, there are several available:
http://www.meritline.com/wireless-rca-video-audio-transmitter-receiver-1w---p-70239.aspx?source=fghdac&gclid=CM6NgaWq-7QCFQ45nAod6EsA3g
Jeff
jautor is offline
post #5 of 5 Old 01-24-2013, 02:03 PM - Thread Starter
Thank you for your help
Reply Home A/V Distribution
