Bought a house thats pre-wired...need help!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-30-2013, 09:49 PM - Thread Starter
lipi128's Avatar
So I just bought a foreclosure that is pre-wired for speakers. There arent any speakers in the walls or ceilings. There are mounts for the speakers along with jacks to plug in banana plugs. Also, there is a surround sound connection wall plate in the master bedroom and a lot of loose wires in the basement where i figure everything is supposed to connect to. I need help as to what i need to get this up and running and what do i do with all the wires in the basement. Thanks for your help!!
lipi128 is offline
post #2 of 10 Old 01-30-2013, 11:11 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
Any in-room volume controls?
By surround sound wallplate I assume you mean the connection for five speakers with locations in the room? That one is easy - just put an AVR there and you're done.
Assuming the rest of the speakers go to the basement, the choices will depend on your budget, desired functionality and the number of rooms. Simplest solution would be a Sonos Connect:Amp unit and an impedance-matching speaker selector. That would give you an all-or-none approach - dividing those rooms into their own zones would be the next step up - which could be individual Sonos units, or an RF-controlled speaker selector like the Aton DLA series.
Jeff
jautor is online now
post #3 of 10 Old 01-31-2013, 02:59 AM
archbid's Avatar
+2 Jeff on Sonos. Make it easy on yourself.
A few more investments:
2. Put together some leads with banana clips on both ends
3. Cheap current meter
Spend a few hours mapping and tidying your wires. I like the idea of faceplates or patch paels even in the wiring closet, but in any case, you should use your banana clip leads to connect the red and black in each room then test which wire is shorted out. Label it for that room and move on.
archbid is offline
post #4 of 10 Old 01-31-2013, 09:32 AM - Thread Starter
lipi128's Avatar
Thanks for responding! No there arent any in-room volume controls.
The wall plate im talking about is similar to this: http://www.amazon.com/Datacomm-45-0069-Surround-Sound-3-Gang/dp/B001C484LA/ref=sr_1_4?ie=UTF8&qid=1359649814&sr=8-4&keywords=surround+sound+wall+plate
So if i buy the sonos connect and plug in all the wires that end in the basement to it, then i would only be able to turn all the speakers on or off correct?
lipi128 is offline
post #5 of 10 Old 01-31-2013, 10:20 AM
jautor's Avatar
Liked: 780
(Connect:Amp is the one you'd want). Yes, and if there's more than two pairs, you'll need an impedance-matching speaker selector.
If you'd like something better than the all on/off (that doesn't require you to go to the basement to make the selections - which make the system almost unusable), look at the Aton DLA speaker selectors which have an RF remote control option. They come in 2/4/6 room models. (If you only need two pairs, I have one of those sitting here new I can sell you)
http://www.atonhome.com/DLA_SpeakerRouters.html
Jeff
post #6 of 10 Old 01-31-2013, 10:24 AM
Gramin's Avatar
Yes. Couple things... you'll need multiple Sonos Connect Amps. One Connect Amp can power up to two pairs of speakers. If you have more than that, you'll need more Connect Amps. Also, the more Sonos devices you have, the more indvidual control you get; that is, independent volume control for each Sonos unit and individual source selection for each Sonos unit. Though you can always have them playing the same music (and still change the volume for each zone).
And for your surround sound zones (master bedroom and LR), you can get the Sonos Connect and plug it into your AVRs. That will then connect those rooms to the rest of your WHA system.
Gramin is offline
post #7 of 10 Old 01-31-2013, 11:22 AM - Thread Starter
lipi128's Avatar
Thanks guys for all your help! So I just looked around again and come to find out basically it's only three rooms that have the mounts on the wall for speakers (bedroom, living room, and sitting area). And then all the wires go downstairs from the looks of it. So if that's the case if I just plug in speakers to those mounts it should be connected downstairs? And then I put that sonos connect down there to connect and use all three at once? Or I can get the Aton thing and control each room individually? Sorry if I sound like a newbie but I've never dealt with this stuff until now but what exactly is an avr compared to the sonos and Aton things? Thanks a ton I really appreciate it
lipi128 is offline
post #8 of 10 Old 01-31-2013, 12:23 PM
jautor's Avatar
Liked: 780
To connect three pairs of speakers to any amplifier (an AVR or a Sonos Connect:Amp), you will need an "impedance-matching" device, otherwise you'll damage the amplifier and it will break. for your situation, the cheapest impedance-matching device will be a speaker selector with that function built-in, such as:
http://www.radioshack.com/product/index.jsp?productId=2462600
And yes, you would place the Sonos "Connect:Amp" in the basement, run its output to the speaker selector, and the three pairs of speakers attach to it. You can choose to turn on/off any of the rooms (zones) at the selector, as long as you're willing to go to the basement to do that.
The Aton unit has an optional RF remote control, so you can make those selections from anywhere in the house instead of going to the basement.
The difference between an AVR and the Sonos unit is a matter of music sources. The Sonos unit has digital library support, Pandora, Internet radio, etc. and is intended to be controlled from a mobile device app. While many AVRs also have these capabilities, the ease of use of the Sonos product makes it a better choice for this application. There is also the P100 / P200 product from NuVo that competes with Sonos - it's very new, though.
Jeff
post #9 of 10 Old 01-31-2013, 09:50 PM - Thread Starter
lipi128's Avatar
So if i buy individual speakers to put in the rooms and then connect the wires in the basement to either the sonos or the aton, then my house should work with surround sound?? The only difference is that the aton i can control from anywhere correct? How would i go about connecting a tv in the living room to this system as well? Thanks
lipi128 is offline
post #10 of 10 Old 01-31-2013, 10:17 PM
jautor's Avatar
Liked: 780
Terminology check - we're not talking about "surround sound" in the 5.1 movie soundtrack definition. We're talking about "whole house audio", aka background / party / ambient music.
Correct, if you get the (optional) RF remote control. But remember the Aton is just a speaker selector - it is not an amplifier. You still need the Sonos with the built-in amp, or something else like it to feed an amplified signal to the speaker selector.
So you can listen to the TV audio in other rooms? You'll need to wire your set-top box, or the TV's analog audio output if it has one, down to the basement to feed into the Sonos line-input. Or you can buy another Sonos for your family room setup, connect to that one, and let the two network together to get the signal to the other rooms. There are some other wireless audio transmitter/receivers that may work for you, too.
Jeff
Reply Home A/V Distribution
