Whole house audio help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-02-2013, 07:15 PM - Thread Starter
rollastone's Avatar
Hello all, Having a house built and have 6 zones. Kitchen, Study, Master Bedroom, Master Bathroom, Kids Bathroom and Outdoor Deck. All have speaker wire from basement where I will put my equipment to volume controls and then going to ceiling speakers. In family room I have my 5.1 system with my Onkyo amp which I would like to incorporate into this setup. Would like to use the Sonos system but I would need 6 connect amps and that would be way over my budget..So would either the HTD DMA-1240 or Dayton Audio MA1240a be an alternative? Could I just hook up the other sonos equipment so I can control with Ipod or Ipad.? Any suggestions would be appreciated on what I should get and how to hook things up.
rollastone is offline
post #2 of 4 Old 02-02-2013, 08:31 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Wire for speakers and keypads, and look at the HTD systems (not just the amp) so that you can attach one or more Sonos Connect (non-amp) units as sources. The difference is that you'll get better zone controls (on/off/volume) from a WHA system as opposed to a multichannel amp with volume controls.
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
post #3 of 4 Old 02-04-2013, 06:59 AM
Den85's Avatar
I've got the 6 zone lync setup. 6 keypads with 3 additional volume controls. I also have a pioneer vsx 1122 that has airplay built in so I use zone 2 on the reciever as the WHA source. Which I guess would give me 10 zones total. Great system from HTD and very easy guys to talk to aswell.
Den85 is offline
post #4 of 4 Old 02-04-2013, 04:51 PM - Thread Starter
rollastone's Avatar
The drywall is already on and there is no Cat5 cable going to volume controls for keypad.I was just going to control everything via Iphone , Ipad when I connect to the sonos system. Is there still a way to use the HTD systems without the keypads? How would I hook this up if I can?
Reply Home A/V Distribution
