CAT6 (non shielded) video runs and using a 6 gang metal box for the multiple tripplite wall plates - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-07-2013, 04:46 PM - Thread Starter
footballcop's Avatar
I am contemplating using a 6 gang metal wall box to house my HDMI wall plates in the closet that houses all my wires for video and audio. I am concerned that using a metal wall box will cause interference with my video signal(s). Let me know if this cause any issues before I install. Any insight would be great.
footballcop is offline
post #2 of 9 Old 02-07-2013, 06:11 PM
SAM64's Avatar
Liked: 78
It won't cause any interference.
SAM64 is offline
post #3 of 9 Old 02-07-2013, 06:19 PM
Glimmie's Avatar
Quoted: 764 Post(s)
Liked: 638
Watch the bend radius though on HDMI cables. The six gang switch boxes are usually just an inch and a half deep. There is an advantage to low voltage rings in that they put a lot less stress on the connection when the plate is pushed back into the wall. They also allow a decent service loop on the wire that just falls back into the wall cavity versus being crunched into a box.
Glimmie is offline
post #4 of 9 Old 02-17-2013, 08:49 PM - Thread Starter
Thanks for the tips
post #5 of 9 Old 02-18-2013, 03:05 AM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
Can I assume you're using tripplite extenders? Looks like they come with wall plates that can't easily be 'multi ganged'.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 9 Old 02-18-2013, 04:58 PM - Thread Starter
You are correct. Single cat6 with power adapter. Got em for $70. Couldn't pass up the deal.
post #7 of 9 Old 02-18-2013, 08:11 PM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
That's quite a deal. You sure it's a single cat cable?
Neurorad is offline
post #8 of 9 Old 02-21-2013, 07:43 PM - Thread Starter
Yup. TRIPP LITE B126-1A1-WP
post #9 of 9 Old 02-22-2013, 10:59 AM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
Not many reviews of that product online - but I did find a few at NewEgg. Phone number to tech support there, if you need it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812228214
Neurorad is offline
Reply Home A/V Distribution
