Combine Two A/V Sources Into One Input (without a switch box) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-10-2013, 11:30 PM - Thread Starter
nintygaming's Avatar
I'm looking to combine 2 "Component" sources into 1 input on the back of my TV, and I would hate to be forced to buy a Selector-Switch Box just to do something so simple for only 2 devices. I know that using a standing Y-Cable will cause interference resulting in a dark or distorted image (even with only 1 source turned on) and that in order to fix this, there would need to be some kind of ohm resistance built into the splitter I think?
I've searched like crazy and all I can find is this- http://www.avsforum.com/t/1202569/combine-via-y-cables-two-rca-outputs-into-one-input-okay - and thus I cannot find one real answer or "Combiner Cable" that can do what I want to do.
Surely something exists that would allow what I want to do. Can anyone point me to a splitter cable that has some kind of ohm resistance built in to avoid interference?
nintygaming is offline
post #2 of 13 Old 02-10-2013, 11:58 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Are the sources really "component video"? Actually, in this case if you can run HDMI instead there are auto-switching solutions. 2 HDMI devices in, one output which will auto-select based on power-on/off or port prioritization... I bought one off Amazon for like $10 and while it was a bit flaky to setup (didn't like a particular input on a Samsung TV), after some trial-and-error it works solid.
Jeff
jautor is offline
post #3 of 13 Old 02-11-2013, 07:50 AM
SAM64's Avatar
Liked: 78
No, they don't exist. Use a switch.
SAM64 is offline
post #4 of 13 Old 02-11-2013, 12:32 PM - Thread Starter
Jeff
Yes it truly is component. The particular TV in question does only component or composite.
post #5 of 13 Old 02-11-2013, 12:51 PM
jautor's Avatar
Liked: 777
Monoprice has a great 4-input component video switch with IR control for <$20... It will even learn an IR code for another device, so you can make the switching work with most any remote...
jautor is offline
post #6 of 13 Old 02-11-2013, 01:26 PM - Thread Starter
After reading many reviews of alot of these kind of devices, almost all of them seem to degrade the picture quality. This seems to be the trend for the powered ones, unlike the non-powered ones. I wonder why they all seem to have this problem?
post #7 of 13 Old 02-11-2013, 02:18 PM
SAM64's Avatar
Liked: 78
Not as much as your idea of paralleling two video sources.
they don't
SAM64 is offline
post #8 of 13 Old 02-11-2013, 02:23 PM
jautor's Avatar
Liked: 777
I have one of these Monoprice units, never noticed any picture issues, nor would I expect one. Simple switches won't do anything to affect image quality.
jautor is offline
post #9 of 13 Old 02-11-2013, 02:24 PM - Thread Starter
Originally Posted by SAM64 View Post
they don't
Yes they do, read the negative reviews on most of the powered ones and see for yourself. (amazon.com). Heck I had two powered one's 8 or so years ago and they distorted the picture quality, so I sent them back. Yet two other Sony models (non-powered) displayed the picture quality as-is. Unfortunately they are composite-s-video only.
post #10 of 13 Old 02-11-2013, 02:41 PM
jautor's Avatar
Liked: 777
Oranges vs. kiwis, then.
Just get the Monoprice one like I did, then, which has 91% positive reviews... And you can always return it.
jautor is offline
post #11 of 13 Old 02-12-2013, 09:01 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
Another vote for the Monoprice one. I've been using mine for 6 or 7 years. Along with my Harmony remote, you wouldn't even know it's there smile.gif
NickTheGreat is offline
post #12 of 13 Old 02-12-2013, 01:01 PM
SAM64's Avatar
Liked: 78
Yes they do,
No, they don't. 'ALL' powered switchers do not have problems...users like you do.
SAM64 is offline
post #13 of 13 Old 02-12-2013, 04:46 PM
BiggAW's Avatar
Quoted: 492 Post(s)
Liked: 120
Back in the day, a friend had a passive one for cable, PS3, and XBOX, and it was fine, no degradation. A good quality one should be fine.
BiggAW is offline
Reply Home A/V Distribution
