Using in-ceiling speakers for both rear surrounds and whole house audio - AVS Forum | Home Theater Discussions And Reviews
Old 02-19-2013, 04:10 PM - Thread Starter
nonstopdoc1's Avatar
Quoted: 106 Post(s)
Is there a way one can use 2 living room in- ceiling speakers (as part of wired sonos based whole house audio) for rear surrounds from living room system also. Living room will have AVR powering a LCR soundbar.
I want to avoid installing 2 extra speakers. Will DVC speakers do the job? Can I add some sort of local interrupt in wall?
nonstopdoc1 is offline
Old 02-19-2013, 04:18 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 779
Yes, a speaker selector with a 12V trigger will do this. Xantech has one that is also IR controlled, but 12V trigger would be the automatic way...
http://www.xantech.com/Controls/VolumeControls/SpeakerSelectors/SR21/
I've done this in my bedroom setup (same thing, AVR with an LCR speaker, in-ceiling surround / WHA setup). I used the NuVo Local Source Interrupt since it's easily integrated. Their 12V model may be a general-purpose solution, too.
Jeff
jautor is offline
Old 02-19-2013, 07:46 PM
Slider_09's Avatar
You can also look at the Niles SAS-1 or SPK-1. I just bought a Niles SAS-1, it can be used to auto switch you rear surrounds, as well as your sub.
Slider_09 is offline
Old 02-19-2013, 09:55 PM - Thread Starter
Quoted: 106 Post(s)
Jeff
Thanks for your reply. How do you install these switches? Can they be installed in wall or do I have to keep them in my AV rack? I apologise for this noob question.
Old 02-19-2013, 10:34 PM
jautor's Avatar
Liked: 779
Neither of these units can be put in the wall - and you've got to run speaker wire, trigger and power to them. You can place it near the AVR or in your central closet AV rack - but somewhere all the wires have to come together...
jautor is offline
Old 02-20-2013, 12:24 PM
VinnyS's Avatar
Liked: 54
You can take a look at this unit made by Russound. I actually have this unit installed for the same application as you. Didn't want two pairs of speakers so I prioritized my surround sound so that when I turn on my AVR, it bypasses my multi-room audio system. This does automatic switching.
Get all your A/V News at: AVS Latest News
Like AVS Forum on Facebook
Follow AVS Forums on Twitter
AVSForum
Bringing the AV Community Together
VinnyS is offline
Old 02-20-2013, 01:34 PM
jautor's Avatar
Liked: 779
I hadn't seen that Russound piece. That's a great implementation. Adjustable auto-sense, gets rid of the trigger wiring (still needs AC power of course). Price is very reasonable,too.
jautor is offline
Old 02-26-2013, 08:24 PM - Thread Starter
Quoted: 106 Post(s)
Jeff
Would something like this work with in wall installation?
http://www.pyleaudio.com/sku/PVCS5/In-Wall-AB-SpeakerSource-Switch
Old 02-26-2013, 08:55 PM
jautor's Avatar
Liked: 779
If you want to settle for a manual switch, a simple one-button would be more appropriate:
http://www.crutchfield.com/p_190ABA1DW/Niles-ABA-1D-White.html?tp=2081&kw=&org=pla&nw=g&crv=15802862185
jautor is offline
