Going Sonos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-23-2013, 08:59 PM - Thread Starter
horsegoer's Avatar
http://www.google.com/search?q=high+ranch+house&hl=en&client=safari&source=lnms&tbm=isch&sa=X&ei=XYopUfWFEaXH0QH0lYCICA&ved=0CAkQ_AUoAQ&biw=768&bih=900#biv=i|37;d|Y3rPm1aKaBWTfM:
Ok not sure if this link will work . I think I am going to go with the Sonos system. I wanted advice whether just one speaker system either the playbar or Play 5 will be enough sound for the kitchen, dining and living area? We opened the entire areas up so it's basically one big room. I would set either the Play 5 or playbar up right under the tv. I mean no matter where we would be standing in either room we would be about 15-20' from the speaker. Can't see how it would not be loud enough. If so which speaker am I better off with? Thanks
beau
horsegoer is offline
post #2 of 9 Old 02-27-2013, 09:54 AM
Phlegm Hankie's Avatar
Quoted: 37 Post(s)
The Playbar hasn't gone on sale yet so there's no way to know how it compares sonically to the Play:5. I'm waiting to hear for myself, I have two Play:5's set up as a stereo pair, and I plan to do some comparative listening between them and the Playbar when it arrives.
My hunch is that the Playbar will have fuller sound than a single Play:5, as it boasts nine drivers to the Play:5's five, but won't match up as well to the stereo pair. In any case I intend to use the Playbar for tv watching.
Phlegm Hankie is offline
post #3 of 9 Old 02-27-2013, 10:17 AM
Joe Fernand's Avatar
Quoted: 286 Post(s)
Liked: 167
If you plan to listen to the TV via Sonos a TV with Optical out and a PLAYBAR is a better option than a TV with Stereo Out and a PLAY:5 as the PLAY:5 has an audio delay whilst it processes the analogue audio so video and audio end up out of sync - the digital Input on the PLAYBAR (DD only - no DTS) has no processing delay!
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
post #4 of 9 Old 03-01-2013, 02:50 PM - Thread Starter
horsegoer's Avatar
Is the playbar meant to be a "surround sound" type of setup or do u still need rears, sub etc.? Thanks
beau
post #5 of 9 Old 03-01-2013, 09:54 PM
Brian B's Avatar
Quoted: 234 Post(s)
Liked: 101
It's an L/C/R. You can add the sub or a set of Play3 for surrounds if you like.
B.
Brian B is offline
post #6 of 9 Old 03-02-2013, 05:31 AM - Thread Starter
horsegoer's Avatar
Got it. Thanks.
beau
post #7 of 9 Old 03-02-2013, 05:36 AM
ntculenuf's Avatar
had a chance to listen to music through the play bar with the sub hooked up to it. IMPRESSIVE to say the least. Going to a sonos training on tuesday and should get some more time with it.
ntculenuf is offline
post #8 of 9 Old 03-11-2013, 01:54 PM
glennQNYC's Avatar
Liked: 31
Sonos Sub, Playbar, Bridge, and a pair of Play 3 = $2045! Too much coin for closed, mid-fi (at best) system IMO.
dream in algorithms
twitter
glennQNYC is offline
post #9 of 9 Old 03-12-2013, 07:08 AM
ntculenuf's Avatar
yes it is. I do like the streaming capabilities and ease of use. I also see the the market for what they offer. but yeah expensive. definitely less expensive ways to get HT and streaming music and better sound.
Reply Home A/V Distribution
