Structured Wiring Setup - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 42 Old 04-16-2013, 04:04 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
Originally Posted by BiggAW View Post
What are you doing with 8 cable outlets?
This seems like a silly question. I have some customers with 20-24 cable outlets, nearly all of which are connected & in use.
cshepard is offline
post #32 of 42 Old 04-16-2013, 06:13 PM
BiggAW's Avatar
Quoted: 501 Post(s)
Liked: 125
I don't want to see their cable bill. Or how much they spent on all those TVs!!!
egnlsn likes this.
BiggAW is online now
post #33 of 42 Old 04-21-2013, 07:36 AM
ctviggen's Avatar
Quoted: 116 Post(s)
Liked: 32
I have around 8 cable outlets in rooms, but none of them are in use (I use HD homerun and homerun Prime, so I get everything from my network). I only have two "TVs" though (one plasma, one projector). I couldn't see having a house big enough to need 20 TVs and if my house was that big, I still wouldn't have 20 TVs.
parrothead123 likes this.
Bob
ctviggen is offline
post #34 of 42 Old 04-24-2013, 06:41 PM
WhiteJ's Avatar
Quoted: 49 Post(s)
Liked: 34
Hey all I have a question I haven't seen a answer to yet. I'm updating my smc and will be installing a 16 wire multi switch. What do you guys do with the four or more cables from dish to the house? Run in conduit or just secure with clips until the in at the house? Sorry I wasn't sure if this should go in here or dtv forum. Thanks guys.
Harmony Elite, UN65F9000 with SEK-3500, Denon 3808CI, Denon 2500BTCI, HR54-500, C51-100, C61K-700, Xbox 360, Chromecast 2.0, Mythos ST, Mythos Ten, Mythos Gem XL, Supercube Reference, Belkin PF60, Tartan and Monoprice cables, Zone 2/3 AW5500.
WhiteJ is online now
post #35 of 42 Old 04-24-2013, 11:45 PM
acesat's Avatar
Conduit is great but it's pretty rare in most homes, so your tech should clip it to the side of the house for you. You/they can often tuck a run of dual cable behind the trim to minimize the visibility but 4 cables is harder to hide than 2. I don't do directv that often so I'm not 100% sure about their equipment but I was under the impression that they're doing everything with 1 cable now and thus the name SWiM (single-wire multi-switch).
acesat is offline
post #36 of 42 Old 04-25-2013, 01:03 PM
WhiteJ's Avatar
Quoted: 49 Post(s)
Liked: 34
Thanks yea the swim is up to 8 tuners but i am going genie and three dvr s so i will be 11 tuners. Thats why i need a swm 16. Future proofing as well. Thanks again cya.
post #37 of 42 Old 04-25-2013, 05:31 PM
BiggAW's Avatar
Quoted: 501 Post(s)
Liked: 125
A SWiMLine with everyone running off one Genie would allow you to use one cable.
post #38 of 42 Old 04-25-2013, 06:56 PM
WhiteJ's Avatar
Quoted: 49 Post(s)
Liked: 34
Thats if i use the genie clients. I am using 3 hr24 so thats 6 tuners plus the 5 from the genie. If i use the genie and clients, the clients pull of the genie for tuners so yes i could use a swim with that setup and be ok. I want the max amount of tuners possible with room to expand. Or am i mistaken?
post #39 of 42 Old 04-26-2013, 12:41 PM
BiggAW's Avatar
Quoted: 501 Post(s)
Liked: 125
Yeah, if you're doing Genie, you can dump the HR24s and use a single HR44 with the C31 clients. Even with the HR44, with a SWiMLine 8, you'd have the ability to run an HR44, an HR24, and an H25 with a tuner for live and recording off of either DVR.
post #40 of 42 Old 04-26-2013, 01:20 PM
WhiteJ's Avatar
Quoted: 49 Post(s)
Liked: 34
Thanks I might relook at my layout. Thanks again BiggAW
post #41 of 42 Old 05-01-2013, 10:06 AM
Spec4's Avatar
Liked: 24
Originally Posted by lumbergh556 View Post
Interestingly, while checking connectivity in each room with an old netbook...
Curious as to how you used your laptop to test connectivity? I have a CAT/COAX tester that shows if I wired correctly, but did you use the network manager in windows or an app?
Spec4 is offline
post #42 of 42 Old 05-01-2013, 06:00 PM
acesat's Avatar
He probably just plugged a cable into the jack to see if it found his network.
acesat is offline
Reply Home A/V Distribution
