Equipment setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-27-2013, 04:43 PM - Thread Starter
horsegoer's Avatar
Is it possible to have all your AV equipment in a closet? I believe some equipment such as cable box,ATV, Blue Ray require the remote be pointed at it? Thanks
beau
horsegoer is offline
post #2 of 4 Old 02-27-2013, 05:39 PM
petern's Avatar
petern is online now
post #3 of 4 Old 02-27-2013, 05:44 PM - Thread Starter
horsegoer's Avatar
beau
post #4 of 4 Old 02-27-2013, 09:08 PM
DGF
DGF's Avatar
Liked: 39
IR bounces off hard surfaces pretty well, so you could possibly get away with a repeater and a carefully placed blaster inside your closet. Other options include using something like a Global Cache iTach + an iOS or Android app. All depends on how sophisticated you want to get (and how much you want to spend).
Dave
DGF is offline
Reply Home A/V Distribution
