H/K AVR 700 Setup issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-27-2013, 10:56 PM - Thread Starter
SunsetIE's Avatar
I recently purchased a H/K AVR 700 receiver to use with my JBL CS480 5.1 system and an LG 47" LED 3d smart tv. My A/V source for this instance is a verizon fios dvr box using an HDMI cable.
My problem is I have sound, but no video.
Ive got the receiver hooked up and the JBL system assembled and wired. The fios HDMI is plugged into HDMI 1 on the receiver, and I have an HDMI running from the HDMI Out ARC on the receiver to the HDMI 1 In ARC on my tv, but no video to be seen. The source on the receiver front display is set to HDMI 1 aswell.
I have tried using the RCA plugs temporarily to get video to be able to change the settings, but no luck there either.
What have I done wrong?
SunsetIE is offline
post #2 of 3 Old 03-03-2013, 01:01 PM - Thread Starter
SunsetIE's Avatar
Wow, great help people, not even any ideas. Glad i figured out the issue instead of waiting for somebody to help!
SunsetIE is offline
post #3 of 3 Old 07-03-2013, 07:55 PM
hk700user's Avatar
Could you please tell me how you solved the problem? I am having the exact same issue. It seems that there is little help for this because it does not seem to be a very popular receiver. Thanks!
hk700user is offline
Reply Home A/V Distribution
