Just bought a house with Russound built in. But I have a 7.1 Onkyo AVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-01-2013, 10:16 PM - Thread Starter
bytor99999's Avatar
Quoted: 30 Post(s)
Been a long time since I have been able to post at AVS. Nice to be back.
Anyway, we just bought a house which has a Russound CA6.4i
Now I understand what this device is doing in sending audio to zones in the house. It have 4 source inputs. And there is where I am totally confused. If I pass all the audio to those 4 source inputs, then what do I send to my Onkyo AVR.
Now my Onkyo is 7.1 (which is funny cause in the 6-7 years I have owned it, I have never been able to set up all 7 speakers. Only always 5.1. First because out house when we got the Onkyo had a slanted roof that prevented wiring in the the last 2 speakers. Now we move into this house which already had in wall speakers and wiring installed, and of course it is 5 speakers for the TV. I actually have a pair of Polk Monitor 30s speakers sitting in an unopened box that I got 6-7 years ago just waiting to see the light of day when I can finally set up 7.1
Also, there is a button on the wall in the TV room, that when in will be the 5.1 sound of speaker wire directly into the wall, and when out will use just 2 of the speakers for the Russound.
I am planning on not hooking the Onkyo audio out center to the wall speaker for center channel. I have another speaker I want to use, and the wall also doesn't have a subwoofer, which I have and will be coming directly out of the Onkyo
OK. so what hooks into what in regards to the Russound and the Onkyo.
Here are my inputs
1) Apple TV
2) BluRay player (for the wife to play her exercise videos) Otherwise I have only used this twice since I bought it 5 years ago. (The Samsung UI is the worst UI ever built, very unfriendly)
I used to plug those into the AVR, and then the HDMI out to the TV. Speaker wire to speakers.
But now I have the Russound, and man do it have lots of cables to plug in. I am really glad the previous owner really labelled the heck out of them.
So what plugs into what? Audio and Video wise.
Thanks for your help
Mark
bytor99999 is offline
post #2 of 5 Old 03-02-2013, 07:57 AM
Gramin's Avatar
On the top left are four source input connections. You'll want to plug in your CD player and any other sources to those connections. If you want to be able to pipe sound from your TV to the Russound, you'll then need to take the audio out from your STB or AVR and plug it into the Russound.
Bottom left of middle are the 6 speaker connections. That should be self explanatory... plug the speakers in at those locations.
Just above the speaker connections are 6 keypad ports for Cat cables, should you have any keypads installed.
And to the right of those are the pre-amp outputs. Use that if you want to take use a more powerful amp for zones 1 or 2. For example, an outdoors areas would require a little more ooomph, so you'd want to use a bigger amp, and thus the pre-amp ouputs.
Regarding your inputs, you don't want the bluray player as an input on the Russound. The bluray should plug into the AVR, and then the AVR to the Russound. The AppleTV is ok, assuming you're going to use it to stream music. If it's just to stream movies, then I'd also plug it directly into the AVR. Reason being (especially with the bluray) is that you're not going to listen to a movie without watching the movie (I assume).
Gramin is offline
post #3 of 5 Old 03-02-2013, 12:37 PM - Thread Starter
bytor99999's Avatar
Quoted: 30 Post(s)
Thanks Gramin.
Yeah, no CD player for me. Just the BluRay and the AppleTV.
So the Apple TV will show video, but also with iCould Match I will stream my music library. But I believe that Apple TV only has one output the HDMI cable, which I definitely want to plug into the AVR.
So then with the AppleTV into the AVR (HDMI), then AVR into Russound(Speakers) and AVR to the TV (video). will be the wiring. Which means the keypads in the zones will only be able to control the volume. Since the only device attached is the AVR.
Does the Russound have its own internal Radio tuner?
Mark
post #4 of 5 Old 03-15-2013, 10:08 AM - Thread Starter
bytor99999's Avatar
Quoted: 30 Post(s)
So I did take my BluRay audio out to the Russound, while still having the HDMI out to the AVR. So the sound goes to both the AVR and the Russsound and that worked perfectly.
On my Onkyo, I took the Zone 2 Audio out to the Russound, but that does not work. No sound at all. I made sure Zone2 was on on the Onkyo and its output device set to a device that was outputting audio. Went to any of the other rooms and tried everything but no sound would come out. Now I really wanted that to work because I have an AppleTV connected to the AVR and wanted iTune Match to play music that would play in the other rooms.
So now I am looking for an alternative device to do that from say an iPhone or iPad not connected to a dock. Airplay would be perfect, but I think that is only on the newer Russounds.
There is a Bluetooth source for Russound here
http://www.russound.com/product_detail.php?i=3280
But not sure if from my office to downstairs is close enough for the BlueTooth to work.
Maybe if my iPhone and Russound are connected to the same network they can see each other. But again, I am not sure if the Russound is new enough to have that IP Address browser display feature.
Mark
post #5 of 5 Old 03-15-2013, 10:19 PM
Techphil's Avatar
the receiver will only pass analog audio to the second zone. i assume the appletv is a 2nd or 3rd generation and does not have the analog output. you can get a digital to analog converter for the optical out put to goto the russound or directly to the receiver with the hdmi and then use the zone two. you can also get an airport express as an airplay receiver and connect that to the russound and send your music from your phone or ipad that way.
Techphil is offline
Reply Home A/V Distribution
