Cheap way to do continuity testing / labeling wires in home? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-02-2013, 12:47 PM - Thread Starter
RandyL712's Avatar
Just bought a home with lots of pre-wired stuff poorly labeled. There's cat5e, component, and rg6 all running to the basement utility room but I'm trying to make clear what is where so I need a continuity test kit or something I can connect to a wire upstairs, run to the basement, and touch wires until I hear a beep or something.
I'm hoping someone knows what I'm talking about and can recommend a cheap device that will help me with this. My only other idea was to bring a stereo into each room, connect the wires like speakers and bring a small speaker to the basement and connect until I heard sound! I'm sure there's a better way!
RandyL712 is offline
post #2 of 13 Old 03-02-2013, 01:24 PM - Thread Starter
RandyL712's Avatar
Well that was quick - some googling sent me to this, I'll pick it up today and cross my fingers.
http://www.lowes.com/ProductDisplay?productId=3201613
post #3 of 13 Old 03-02-2013, 03:31 PM
falcon999's Avatar
i have been looking for the same thing but that link doesn't work..
falcon999 is offline
post #4 of 13 Old 03-02-2013, 08:06 PM
mystikjoe's Avatar
a cheap multimeter would work to test continuity! do a google search on how. on cat5e you would twist two of the wires together and at other end apply meter you'll hear a beep when you find them. if they are all terminated are you able to put ends back on? with the rg6 a little jumper wire held from conductor to the ground by a friend and you at other end would work. if you aren't comfortable with putting ends on the cat5 you could to it with some thinnner wire but would be a little tricky cause of the size. when finding speaker wires if they are hooked up to speakers use a 9 volt battery it'll make the speaker pop quick and make it easy to locate. hope this helps you a bit. good luck!
mystikjoe is offline
post #5 of 13 Old 03-02-2013, 10:58 PM - Thread Starter
RandyL712's Avatar
post #6 of 13 Old 03-03-2013, 12:34 AM
ifor's Avatar
Quoted: 65 Post(s)
Liked: 72
ifor is offline
post #7 of 13 Old 03-03-2013, 09:32 AM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
This is excellent for RG6
http://www.amazon.com/gp/aw/d/B006962KFW/ref=pd_aw_sbs_hi_2?pi=SL500_SS115
This is what I use for RJ45, but can be found cheaper
http://www.amazon.com/gp/aw/d/B008SD1JME/ref=mp_s_a_1?qid=1362331918&sr=1-17&pi=SL75
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #8 of 13 Old 03-03-2013, 11:11 AM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
Label well, too.
Sharpie works, if white cables.
I've been using a Dymo labeller, polyester labels. Work very well with a flag wrap, but look unsightly.
Not many labels work well with like this, unless you buy label tape this is made to shrink fit with heat:
A simple label wrapped like that though will do well if wrapped with clear heat shrink.
Neurorad is offline
post #9 of 13 Old 03-03-2013, 11:15 AM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
Polyester tape is designed to resist tearing, and last a very long time. Other labels won't do as well, generally.
P-Touch and Brother are other popular brands.
Check the prices on the refills. Dymo is way overpriced. I wouldn't buy it again, for that reason. Otherwise, good stuff.
Neurorad is offline
post #10 of 13 Old 03-03-2013, 07:56 PM
TheSandman13's Avatar
I think what you might be looking for is a wire tracer. You hook a transmitter to one end, and you have the receiver at the other end. The Sperry ET64220 is a fairly inexpensive one. About $40. It will work with a variety of different wires. "Identifies coax, CAT 5, speaker, phone or any non-energized wire"
http://www.homedepot.com/buy/sperry-lan-tracker-wire-tracer-et64220.html#.UTQa2KV2CkR
TheSandman13 is offline
post #11 of 13 Old 03-08-2013, 12:19 AM
archbid's Avatar
I use this. Helps when you start terminating your own cables. Will tell you if you got the wires wrong.
http://www.amazon.com/Tripp-Lite-N044-000-R-Network-Tester/dp/B000VM6TTI/ref=sr_1_2?ie=UTF8&qid=1362730644&sr=8-2&keywords=cat6+wire+tester
archbid is offline
post #12 of 13 Old 03-20-2013, 06:37 PM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
Hey, good idea. What diameter and brand heat shrink works best with most CAT5 and RG6 cabling?
wkearney99 is offline
post #13 of 13 Old 03-21-2013, 03:58 AM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
Let me back track a little. Use a super cheap method for marking labels during pre wire; they will all get cut off. The house trim out - adding plates, and connectors behind walls - I'd use something relatively affordable then too. Nobody will ever see them, but they should be solid. Save the fancy labels for the rack trim out.
I don't have a good rec on a super cheap method.
Neurorad is offline
Reply Home A/V Distribution
