Need help with new setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-04-2013, 08:53 AM - Thread Starter
Nola26's Avatar
Hi all,
I am getting ready to build a new A/V system for the mobile command center at work. Here is a brief overview of what I need to do. I just can't think of how or what I may need to get this done.
We will have the following components installed: CCTV system, DirecTV satellite, DVD player, and 3 computer workstations.
Now I will have 3 or 4 TV monitors installed in the trailer. I need to find a way for any of the monitors to display any of the A/V sources at any time. I need to be able to watch the CCTV system, satellite, or have any of the 3 laptop stations to be viewed on any and all of the monitors in the trailer.
What kind of receiver, if any, are capable of outputting all of these sources to three or four monitors at the same time? It would also be helpful if I only needed to run one HDMI or COAX to each monitor.
Nola26 is offline
post #2 of 3 Old 03-04-2013, 10:32 AM
Alan P's Avatar
Quoted: 5053 Post(s)
Liked: 3732
You need a professional A/V distribution system with a router, not a consumer receiver.
Alan P is online now
post #3 of 3 Old 03-04-2013, 10:58 AM
Joe Fernand's Avatar
Quoted: 355 Post(s)
Liked: 210
'What kind of receiver, if any, are capable of outputting all of these sources to three or four monitors at the same time?' - as Alan P says your barking up the wrong tree with that plan smile.gif
You require a Matrix at the heart of your System plus you need to be clear on what folk expect to see on your various 'TV's' and how and where you wish to control/allow control of the system?
If you wish seamless switching between different signal types and resolutions be prepared to get the big cheque book out!
Joe
PS Here are some we built a long time ago - http://www.tmfsolutions.co.uk/wtmf005-6.htm
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
The Media Factory. Residential and Commercial system Design, Consultancy, Installation, Supply and Integration.
Joe Fernand is online now
Reply Home A/V Distribution
