Multi-room/zone audio system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-08-2013, 02:57 AM - Thread Starter
JT2020's Avatar
Hi, I am completely new to multi-room systems however as I am building a new house I want to dive into this world.
My local hi-fi shop has recommended Sonos, however given that I want to have 6 rooms/zones this seems like an expensive option - plus my understanding is that they are always on drawing 8W per amp.
After doing some research I came across the Dayton Audio MA1240a Multi-Zone 12 Channel Amplifier which looks like a good alternative.
My question is - I would prefer not to have wall mounted controls so can someone recommend an alternative way to control the Dayton please? Your help would be much appreciated, thanks
JT2020 is offline
post #2 of 2 Old 03-08-2013, 06:52 AM
jautor's Avatar
Quoted: 1234 Post(s)
Liked: 789
As 6-zone solutions go, that's not expensive, given the functionality.
That's an amp, not a system, nor a "source". If you want inexpensive solutions, look at HTD.com and use Sonos as a source, but it won't be as simple or easy to use...
If you're building a home you should follow the CEA guidelines for pre-wiring for Whole House Audio. At least pre-wire a cat5e cable to potential keypad locations (don't have to expose the wires, just document where they are behind the drywall), so you can change your mind later.
Jeff
jautor is offline
Reply Home A/V Distribution
