Any MusicPort alternatives that will work with my Nuvo Grand Concerto? - AVS Forum
post #1 of 13 Old 03-18-2013, 08:44 AM - Thread Starter
ace3's Avatar
Hello,
I installed a Nuvo GC in my house about 5 years ago, and have the "original" NVMP Music Port server installed. The MusicPort has worked fine about 80% of the time, but i think it has finally given up and stopped working. I haven't changed anything regarding how it's hooked up, or done anything with the computer it's hooked up to. I had long ago set the computer to reboot every evening, which seemed to help. Now, I can't get the keypads or the ipad app to connect. I try to browse to the website, and it says the server isn't running.
I use the MusicPort 90% of the time just to play Pandora throughout the house, with the other 10% playing something from our MP3 library.
Are there any alternatives (from other companies) that will play Pandora and MP3s? The NV-MPS4 is entirely too expensive just to do that, in my opinion.
Any opinions? Thanks for the help!
"Price is what you pay, and value is what you get." -Warren Buffet
ace3 is offline
post #2 of 13 Old 03-18-2013, 09:22 AM
jautor's Avatar
Quoted: 83 Post(s)
Liked: 343
If anything, try uninstalling and reinstalling the software. Some other update to Windows may have crapped something up... I also see one of the processes crash occasionally, but a reboot usually fixes it. If you've added music recently, there may be a bad tag that causes a crash (I haven't seen that happen, though).
I too have my server set up to reboot every day or two in the middle of the night to deal with the instability - which seems to come mostly from Windows updates and security / antivirus updates that confuse the Autonomic service into thinking the system's being shutdown...
As to alternatives, there aren't any that will produce metadata or offer keypad control other than the MPS4. I'd really like NuVo to enable a connection between their new wireless units and the GC to get the keypad support with the latest server - but so far nothing from them. Once they publish the network APIs for that unit, I may tackle that myself.
Jeff
jautor is online now
post #3 of 13 Old 03-20-2013, 01:17 PM - Thread Starter
ace3's Avatar
Thanks, Jautor ... i'll give an uninstall/reinstall a try this weekend. Too bad about no alternatives!
ace3 is offline
post #4 of 13 Old 03-20-2013, 02:32 PM
jautor's Avatar
Quoted: 83 Post(s)
Liked: 343
I pinged NuVo again today regarding the APIs for the wireless source/systems... They said they're working on it and still plan to release it (and will announce it on Facebook).
post #5 of 13 Old 03-21-2013, 07:31 AM - Thread Starter
ace3's Avatar
That would be great ... really open it up!
ace3 is offline
post #6 of 13 Old 03-21-2013, 07:51 AM
jautor's Avatar
Quoted: 83 Post(s)
Liked: 343
What I really want them to do is create a NuVoNet bridge option for the P3100, so that it would just work. I think that would be a killer product for them, as it would couple the best keypad implementation (in that product space) with the "modern" streaming/server implementation. I told them I wouldn't blink at a $500 dongle to do that...
post #7 of 13 Old 03-21-2013, 08:00 AM - Thread Starter
ace3's Avatar
Agreed. The P3100 would be perfect if it would tie into the GC and let me use my wall mounted keypads.
ace3 is offline
post #8 of 13 Old 03-22-2013, 06:49 AM
ClemsonJeeper's Avatar
Quoted: 55 Post(s)
That's good. That might sway my decision on Sonos vs NuVo. If they fully release the API the NuVo P3100 could be much more easy to integrate than Sonos.
I wonder if they plan on adding new music sources for their wireless systems...
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is offline
post #9 of 13 Old 03-22-2013, 07:34 AM
jautor's Avatar
Quoted: 83 Post(s)
Liked: 343
I made this exact point to them. That if they make their wireless/streamer products easier to integrate than Sonos, they can swing a lot of purchase decisions on THAT difference alone. Given, of course, that the basics are covered, which I think they have.
Jeff
post #10 of 13 Old 06-06-2013, 01:29 PM
jautor's Avatar
Quoted: 83 Post(s)
Liked: 343
Just an update to anyone beside me and Clemson that are interested... NuVo announced the availability of a published API for the wireless system(s). It's a JSON HTTP interface and first glance is that it's pretty easy to use. Access to the specs is controlled, but you can request access via your dealer.
http://www.cepro.com/article/nuvo_readies_wireless_audio_system_for_integration/K5
post #11 of 13 Old 11-17-2013, 05:05 PM
bholden52's Avatar
Just now getting to this posting.
Jautor, I see the benefits of the APIs but it still doesn't get the control to the keypads. Any possible hope of Nuvo getting this in the future? Sure wish they would realize this. I'm actually thinking of Ebay'ing the system I bought and going a different direction
bholden52 is offline
post #12 of 13 Old 11-17-2013, 05:44 PM
jautor's Avatar
Quoted: 83 Post(s)
Liked: 343
I've relayed the same info and feedback to the NuVo development team and talked to their exec's on the topic at CEDIA. Hopefully I'm not the only one that's told them...
Jeff
post #13 of 13 Old 11-17-2013, 09:26 PM
EricPOlson's Avatar
Thanks, that is good to know. I'm glad it is JSON - JSON parsers are easy to find.
That may open up some possibilities.
(It was pretty simple to write a C#/netdruno interface to a DirecTv box using JSON)
EricPOlson is offline
Reply Home A/V Distribution
User Tag List
