BNC to HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-25-2013, 10:51 AM - Thread Starter
cmicken's Avatar
Getting a dome camera with BNC a output. I need to make a run of about 70ft to the AV closet. At the closet I have a HDMI splitter that will split the camera feed.
What is the best way to go from the bnc output of the camera- 70 ft to the HDMI input of the HDMI 3-port splitter that feeds the TV's?
cmicken is offline
post #2 of 6 Old 03-25-2013, 12:36 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
The simple answer to that is to buy a security DVR to handle the camera feed and providing a digital output... Analog camera converting to a digital signal by itself probably isn't a good path... Pick a different camera or another solution.
jautor is online now
post #3 of 6 Old 03-26-2013, 09:58 AM
M1chael's Avatar
Quoted: 12 Post(s)
I also think they make video balun's on ebay. Something like this:
http://www.ebay.com/itm/4pcs-2-pair-Passive-Video-Balun-BNC-to-UTP-Cable-Connector-for-CCTV-Camera-DVR-/221151044373?pt=US_Surveillance_Cables_Adapters_Connectors&hash=item337da12315
Not sure if this will help you or not...I was considering this before I switched from analog to ip cams to get the signal from the cam to my TV.
M1chael is offline
post #4 of 6 Old 03-26-2013, 01:50 PM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
Yes, these are good for analog only but to convert the cameras analog video to HDMI is quite complex - especially if color video is needed. The analog NTSC video would need to be decoded to RGB, digitized, deinterlaced, scaled, and then formatted to HDMI. Quite possible to do and there probably are some boxes that do it but my guess is we are looking at several hundred dollars to start.
Glimmie is offline
post #5 of 6 Old 03-26-2013, 02:26 PM
absolootbs's Avatar
Quoted: 18 Post(s)
Liked: 27
i'm not super familiar with the details of security camera output, but maybe one of these, plus one of these? the 70ft part would be up to you. there are any number of types of cable combined with various adapters/"baluns" that would work.
absolootbs is offline
post #6 of 6 Old 03-26-2013, 08:09 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
http://www.atlona.com/Atlona-Composite-Video-BNC-Stereo-Audio-to-HDMI-Video-Format-Converter-and-Scaler.html
I think we have a couple of these at work. If you need a price, PM me.
B.
Brian B is offline
Reply Home A/V Distribution
