Pre-wire how to? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-27-2013, 05:29 PM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
Im getting ready to run some speaker wire to various rooms in our under-construction house and I want to make sure I do this right.
The builder already wired CAT5 to various rooms and also speaker wire/volume control for the patio, but no other rooms.
I bought some 14/4 and 14/2 in-wall CL2 rated speaker wire from Monoprice and my plan is to run the 14/4 wire from the media wall outlet area (where the builder ran the wires to) to each room, down the wall to an area where a volume control will go, and then 14/2 wire from the volume control to the ceiling in two spots (for two speakers per room). That is all that is needed right? Want to make sure I'm not leaving something out.
I figure I'll run the wires along the same route the builder used and tie them with zip ties to the same anchor points that they did, plus use some foam insulation for the holes I make.
Here are some pictures from how the builder wired and left everything...
HX_Guy is offline
post #2 of 7 Old 03-27-2013, 06:22 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
Run a cat5e cable to any volume control location in addition to the speaker wires. You want the ability to add keypads instead of being limited to just simple volume controls in the future.
And yes, wire as many zones as you can - it will never be this cheap or easy to do, and for most folks, if it's not pre-wired, it will never get done.
Jeff
jautor is online now
post #3 of 7 Old 03-27-2013, 08:06 PM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
Are there cables available that have 14/4 wire inside and also CAT5 all wrapped up in one? I am assuming that is what the builder installed as it's a big fat purple cable and it says 16/4 on the side but has a lot more wires inside the sleeve. That would definitely make it a lot easier than running two cables (14/4 & CAT5)
Edit: Wow, looks like there is that kind of cable, and it's expensive as hell! eek.gif
http://www.cablingplus.com/products/14-4-cat5e-structured-cable
HX_Guy is offline
post #4 of 7 Old 03-27-2013, 08:09 PM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
Also, was it overkill to go with 14 gauge wire? My longest run will probably be in the 40' range.
HX_Guy is offline
post #5 of 7 Old 03-27-2013, 09:28 PM
jautor's Avatar
Liked: 780
Yes, there is. And YES, it is... Which is why we don't see it used very much. Pulling two wires to the same location isn't a big deal, especially when it's DIY labor. wink.gif
Yes, but it certainly doesn't hurt anything.
post #6 of 7 Old 03-27-2013, 09:35 PM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
Except my wallet...the 14/4 was about twice the price of 16/4. mad.giftongue.gif
HX_Guy is offline
post #7 of 7 Old 03-27-2013, 09:41 PM
jautor's Avatar
Liked: 780
Use a Sharpie and write "MONSTER" a few times on the cable. Then you'll feel like you got a bargain! biggrin.gif
Reply Home A/V Distribution
