running Cat6 in new house - - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-29-2013, 03:48 PM - Thread Starter
ohliuw's Avatar
I know this has been discussed zillion times, but I couldn't find my answers. I will be wiring my new house with Cat6, and I am a unclear on some things. Only done this in rooms with rised floors and suspended ceilings with conduits alredy installed. So I have no idea what to expect running in walls around wood.
So far I've got my cable, keystone jacks, panel and front plates. What I am not sure about is:
1. How am I supposed to attach the cables to the wood?
2. Do I just leave the end of the cab le hanging at the place I want to have the jack installed in the wall, or I should use some sort of wall box to make sure that they will cut the drywall at the place I I want it?
2. If I need wall box, which one should I use? The same model they use for the power outlet? Do I have to attach it to the wall?
thanks!
ohliuw is offline
post #2 of 14 Old 03-29-2013, 04:45 PM
ifor's Avatar
Quoted: 62 Post(s)
Liked: 72
http://lmgtfy.com/?q=insulated+wire+staples
Leave the cable loose and don't crush the cable.
2. Do I just leave the end of the cable hanging at the place I want to have the jack installed in the wall, or I should use some sort of wall box to make sure that they will cut the drywall at the place I I want it?
http://lmgtfy.com/?q=nail+on+low+voltage+bracket
The drywallers will cut the drywall around this box. Make sure to match the height of your other boxes in the room or wall.
thanks![/quote]
ifor is offline
post #3 of 14 Old 03-29-2013, 05:59 PM - Thread Starter
ohliuw's Avatar
thanks, any pros or cons of using an electrical box vs a braket? The electrical boxes are 30c at Lowes, whereas the brackets go for a buck.
ohliuw is offline
post #4 of 14 Old 03-29-2013, 06:06 PM
olyteddy's Avatar
Quoted: 531 Post(s)
Liked: 931
Brackets don't bend the wire as much.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 14 Old 03-29-2013, 06:32 PM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
If there is any other construction going on anywhere around you, do yourself a favor and walk through some sites that are at that stage. You'll learn a lot from seeing how it's been done by the trades...
+1 to all the other advice given so far.
Jeff
jautor is offline
post #6 of 14 Old 03-29-2013, 06:42 PM - Thread Starter
ohliuw's Avatar
ohliuw is offline
post #7 of 14 Old 03-29-2013, 09:17 PM
ifor's Avatar
Quoted: 62 Post(s)
Liked: 72
ifor is offline
post #8 of 14 Old 03-31-2013, 07:28 PM
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
This is the way Ive seen it attached in homes under construction..
HX_Guy is offline
post #9 of 14 Old 03-31-2013, 09:57 PM
roddymcg's Avatar
This is how I secure wiring as well. As for the low voltage rings:
http://www.aifittings.com/catalog/communications/low-voltage-mounting-brackets-for-new-construction/
Much easier to use your cordless screw gun and go to town. Much easier to adjust when screw up too. No need for closed boxes if you do not need to use them in your area. You end up crushing your Catx cables in the box, or making the wire so short is is harder to terminate.
roddymcg is offline
post #10 of 14 Old 03-31-2013, 11:26 PM
Colm's Avatar
Liked: 94
Colm is offline
post #11 of 14 Old 04-01-2013, 04:16 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Lots of options for fastening category cables to studs - just don't pinch them with horseshoe nails designed for Romex.
If you're using spray foam, which expands, use something fairly sturdy, and space them closer together.
In the wiring closet, leave a lot of slack, tape the bundle up inside a clear bag if drywalling, and don't let people step on the bundle.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #12 of 14 Old 04-01-2013, 04:19 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
You definitely don't want junction boxes with enclosed backs, for LV cables.
Arlington makes some nice TV boxes, for on-wall displays, but there are many manufacturers of combined LV and line-voltage boxes.
Neurorad is offline
post #13 of 14 Old 04-01-2013, 07:08 AM
Skytrooper's Avatar
Quoted: 223 Post(s)
Liked: 144
Some say using wire ties to secure Cat Cable to studs is a bad idea, supposed to distort the electrical characteristics of the cable. I used wide curved plastic hangers and velcro on my home. Just saying.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #14 of 14 Old 04-01-2013, 08:55 AM
billdacat's Avatar
Quoted: 17 Post(s)
If you put the ties on loose, they are ok...You never want to crush the cable; and watch out for kinks....
billdacat is offline
Reply Home A/V Distribution
