Finshing my basement. Need advice on a box to to distribute my DTV HD signal - AVS Forum | Home Theater Discussions And Reviews
Old 04-08-2013, 06:15 AM - Thread Starter
Royal05Steve's Avatar
I currently have DTV HD (1 cable in to a multiplexer out 3 receivers) This multiplexer is just installed up in my floor joist. It want to move it to some sort of in wall box (like a breaker box) to have more options in the future and easy to get to as I am refinishing my basement and this will be covered with drywall soon. Any suggestions on this?
Royal05Steve is offline
Old 04-08-2013, 07:22 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You need to decide on the size, depending on what else you want in there.
Search cocoontech forums for 'enclosure' for tips and tricks.
I've been happy with Channel Vision enclosures.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 04-10-2013, 05:15 AM - Thread Starter
