Need an ir repeater for single cable box located directly behind wall mounted tv. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-19-2013, 06:56 PM - Thread Starter
Chillout2010's Avatar
I am looking to store my cable box behind my tv. It is a wall mount 40" tv that is mounted over a fire place. I'd like a simple ir repeater that can feed the signal to the box and not be overly noticeable when attached to the top of the tv. Any suggestions?
Chillout2010 is offline
post #2 of 8 Old 04-19-2013, 09:27 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
Mount the box with the front facing up towards the ceiling. Point your remote at the wall/ceiling above the TV. I bet you won't need the IR repeater.
If you want one anyway, look at Xantech.
cshepard is offline
post #3 of 8 Old 04-19-2013, 09:54 PM
kingpin748's Avatar
Monoprice.com
Dualband repeaters for $17. I've setup 3 of these without issue.
kingpin748 is offline
post #4 of 8 Old 04-20-2013, 02:42 AM - Thread Starter
Are you referring to this from merit line?
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011009&p_id=9194&seq=1&format=2
Also I see Wal-Mart sells an xantech repeater system for up to four devices for $75 is that the going rate? http://www.walmart.com/ip/16954429?wmlspartner=wlpa&adid=22222222227000000000&wl0=&wl1=g&wl2=&wl3=21486607510&wl4=&wl5=pla&veh=sem
I really only need one device connected. I'd like to be able to connect my laptop via hdmi wirelessly too but that a whole different device. But other then that if the cable box works I'd be s happy camper. I'm going to be doing this on two TVs and one is gonna need one of these no matter what since the box is gonna be placed under a dresser and wired through the wall.
post #5 of 8 Old 04-20-2013, 07:00 AM
ClemsonJeeper's Avatar
Quoted: 228 Post(s)
Liked: 139
No, I believe he is talking about this one:
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011009&p_id=9895&seq=1&format=2
November 2015 HT of the Month: The Vortex Theater
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is offline
post #6 of 8 Old 04-20-2013, 07:33 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Which cable/Tivo box? Brand, model. Find the manual online.
It may have a direct IR input. My Comcast mini STB had one. Actually, IR receiver and cable came with it.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #7 of 8 Old 04-20-2013, 07:36 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011009&p_id=8060&seq=1&format=2
$3
I don't think the IR input jack would need to be configured in a settings menu, but it's possible.
Neurorad is offline
post #8 of 8 Old 04-23-2013, 09:32 AM
Bryan J's Avatar
I got one of these :-
http://www.keene.co.uk/electronic/keene-electronics/keene-ir-distribution-extender-kit-%28fascia-rcvr%29/irbkitf.html
Works really well and can control loads of different devices.
Bryan J is offline
Reply Home A/V Distribution
