Black Structured Media Enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-22-2013, 09:10 AM - Thread Starter
Overlord66's Avatar
Does anyone make a black structured media enclosure? I've seen the Leviton versitle panel and it would work but I'm looking for something a little larger.
I want it in black so that it matches my rack and wall mounted patch panel.
Overlord66 is offline
post #2 of 2 Old 04-22-2013, 01:26 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
A quick search of black + low voltage enclosure shows Leviton makes one.
I expected Panduit to have one - quick review of their website shows no standard black enclosures.
An auto body shop could paint any steel enclosure black, and the finish would be more durable than if done with ordinary black spray paint (which is another option). Bring a blank rack plate to the shop, to match the finish (wide variety of black finish options).
You could also just paint the door of the enclosure; nobody but you will see the interior of the LV enclosure. Most LV enclosure doors cover the whole front of the enclosure, although YMMV
Edit - paint cover only if recessed/flush mount; paint enclosure too if surface-mount. wink.gif
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home A/V Distribution
