Standalone Amplified In-Wall Volume Control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-22-2013, 01:41 PM - Thread Starter
testaj's Avatar
I've found this thread via search:
http://www.avsforum.com/t/1003275/non-a-bus-amplified-volume-control
I'm looking to do the same thing. Essentially, I want the "look" of the distributed audio system in my garage, but it won't be hooked into a system for quite some time...if at all. I've been looking at Russound products, but also the Channel Vision AB-124.
Does anyone have the specs for the AB-124? I'm looking for what color pairs do what, and what the input voltage and required current to power the switch/amplifier is?
Are there any other manufacturers/models I should be looking at that may be easier to use?
Thanks in advance for your help!
testaj is offline
post #2 of 2 Old 04-28-2013, 03:57 PM
scl23enn4m3's Avatar
scl23enn4m3 is offline
Reply Home A/V Distribution
