? About C2G / Cables to Go 40574 TruLink HDMI over Coax - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-27-2013, 05:45 PM - Thread Starter
Brett_FL's Avatar
Wondering if anyone has used one of these C2G / Cables to Go 40574 TruLink HDMI over Coax systems? I bought one to get HDTV down to the lake where I already had coax cable run.
The system seems to work well with a very good picture however it loses signal every 10 minutes give or take for a split second or two then comes right back. Any ideas?
Brett_FL is offline
post #2 of 2 Old 07-31-2013, 05:03 PM
tcppro's Avatar
did you get this working? from what I've read elsewhere you might have to set the refresh rate to 59Hz.
tcppro is offline
Reply Home A/V Distribution
