HTD, iTunes "source" - AVS Forum | Home Theater Discussions And Reviews
Old 04-30-2013, 07:34 PM - Thread Starter
nicholsps's Avatar
All,
Finally just got my HTD system setup. I'm going to stream my iTunes library and trying to figure the best way to do this through the HTD unit. Was going to use the Sonos "Connect" but seeing how it's 349$, was wondering if there are other options. Will probably get a Sonos Connect, or 2, to connect to Sirius and Pandora, but what would you consider for streaming iTunes? Thoughts and suggestions, please.
nicholsps is offline
Old 04-30-2013, 11:07 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
For an iTunes library housed on a PC / Mac running iTunes - the Apple Airport Express with the Remote app...
If it's stored on a NAS, then the Sonos Connect. Which given the integration of all the Internet streaming sources in addition to the digital library, may be a better answer anyway.
Jeff
jautor is offline
Old 05-02-2013, 10:51 PM - Thread Starter
nicholsps's Avatar
Would you just connect it via the Audio Cable into a Source input on the HTD controller? That's not a bad option for just controlling iTunes, seeing how it's only $99 compared to the SONOS Connect at $349. I plan to get a connect for control of Pandora/XM and other stuff, but then have a dedicated system that would always be streaming iTunes... This good idea?
Old 05-02-2013, 11:02 PM
jautor's Avatar
Liked: 777
Yes...
If you want a second source for simultaneous use, then it is a cheap way to provide access to the iTunes library. But it is yet another app/control method. The Sonos can get to the digital library, too.
jautor is offline
Old 05-08-2013, 02:12 PM
bakerybum's Avatar
I have a similiar set up and issue/problem, let us know what you decide and if it works. I was thinking about adding a squeeze box and outputting that to a keypad source and using a cheap tablet running squeezebox app. I want to be able to utilize my library as well as use pandora, slacker, etc as a source
and use my android device as controller.
bakerybum is offline
Old 05-08-2013, 03:13 PM
jautor's Avatar
Liked: 777
If you don't have a squeezebox device already, you'll be better off with a Sonos Connect as a source. Current / supported product under active development.
jautor is offline
