Speaker Selector with Dual Source Inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-02-2013, 07:29 AM - Thread Starter
Blue's Avatar
I have a deck being converted to an enclosed new house space. I want to be able to drive the front speakers of the surround sound in the new room either through the system in the main house (so that we can have consistent music throughout during a party) or through the system dedicated to that room (such as when we are watching a movie out there or listening to music that is different from what is playing in the rest of the house). Conveniently, there are speaker wires from the system in the main house already pulled to the deck/new room from the outdoor speakers I used to have there. I found a speaker selector from Monoprice that allows you to input two different sources and select which one will feed the speakers. Does anyone have experience with something like this? Is there any reason I should avoid it? In other words, would this kind of speaker selector be expected to denigrate the sound quality?
__________________________________________________ ___________________________________________
Formerly known as GatorBlues. The Spinal Tap Theater build:
http://www.avsforum.com/forum/19-ded...ter-build.html
Blue is online now
post #2 of 3 Old 05-02-2013, 03:26 PM
ifor's Avatar
Quoted: 65 Post(s)
Liked: 72
Don't bother trying to use a speaker switch, look at something that will utilize the new rooms receiver inputs from the main system.
Look at an audio balun.
ifor is offline
post #3 of 3 Old 05-03-2013, 05:39 AM - Thread Starter
Blue's Avatar
That's a great idea, which I completely overlooked. Thanks!
Blue is online now
Reply Home A/V Distribution
