Whole house audio I can control via serial or an API? - AVS Forum | Home Theater Discussions And Reviews
Old 05-04-2013, 10:18 AM - Thread Starter
detzx's Avatar
Something like this (http://www.amazon.com/Russound-Multizone-Controller-Amplifier-System/dp/B001F6CDYY/ref=pd_sim_sbs_e_3) that allows me to control the source selection and volume through an api or something. I want to play certain things went events happen around my house (baby is awake, someone pulled in the driveway) as well as a simple app (i'm making) to switch sources so I don't have keypads in every room. Any thoughts, maybe I'm looking in the wrong direction?
detzx is offline
Old 05-04-2013, 02:18 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Take a look at CQC. Find out what multi zone systems integrate well with it - see what others have used. Search the CQC forum.
Another option would be Homeseer, plus a multi zone system.
CQC would be more powerful and flexible that HS, IMO.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 05-05-2013, 07:27 PM - Thread Starter
detzx's Avatar
Hey, I'm not looking for the software to do it I'm looking for the hardware that supports commands (IR, RS232, etc) so I can send it commands to switch sources, change volume etc. I found this which I like but there doesn't appear to be a way to control it other than their build in keypads and remotes.
http://www.smarthome.com/83585/Channel-Vision-P-1044-4-Source-4-Zone-Cat5-Audio-Matrix-Switcher/p.aspx
detzx is offline
Old 05-05-2013, 08:04 PM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
Most of the WHA systems have interface(s) to allow commands to be entered. Anything that claims "integration" support, or lists any of the automation system vendors as partners will have one or more. NuVo has a published RS232 spec (and IP if you have one of the server products attached), HTD has their protocol documented (I believe you have to request the doc), and I'd expect Russound has theirs published as well.
jautor is online now
