Whole House Question: Left Spkr, Right Spkr, Mystery Cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-08-2013, 01:00 PM - Thread Starter
Kor
Kor's Avatar
Hey everyone,
I'm new to whole house audio as I just bought a pre-wired home.
There are 2 speakers in each room, plus a volume dial on the wall.
At the hub, I am getting three cables. One is labeled Left and has both red/black wire wrapped in the sheath. One is labeled Right and has both a red/black wire in the sheath. There is a third wire from each room, cat5 cable from the looks of it but its cut not terminated with a plug.
What the heck is this cat 5 cable for? The home builder told me it's "for the volume control". ?
I am getting zero help from the builder and there are zero manuals.
Is this a common thing....?
Kor is offline
post #2 of 6 Old 05-08-2013, 01:04 PM
AV_Integrated's Avatar
Quoted: 990 Post(s)
Liked: 728
Instead of using traditional volume controls it is for a smart keypad which gives you local room source select, volume control, and device control.
Read the 4th post in this thread as I just went over it with someone else...
http://www.avsforum.com/t/1471690/multi-room-audio-need-solution
It's pretty slick, but will cost more to setup than a traditional volume control system.
If your speaker wires are run through the single gang box near the door of each room, then you will find the cat-5 in there as well and you can choose to either use a traditional volume control or you can use a smart keypad.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 6 Old 05-08-2013, 01:25 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 781
Yes, it's for a keypad, which is generally part of a whole house audio (WHA) system. The fact that the cat5e cables are there mean your builder wired the house "correctly"!
Jeff
jautor is online now
post #4 of 6 Old 05-08-2013, 01:44 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
The category cable could also be used for distributed IR, from the VC location; cheaper source control than a Smart KP.
If the speaker cables run to the VC location before running to the speakers, an ABus or Digi5 system could be used. Not a premium solution, but on the cheaper end of WHA systems.
The category cable could also be used to supply an iPod/dock as an audio input, or power an on-wall/in-wall tablet, iTouch, or conventional phone dock.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #5 of 6 Old 05-09-2013, 08:35 AM - Thread Starter
Kor
Kor's Avatar
Thanks you guys are awesome.
Any idea how I would 'test' the cat5 cables? Any way for me to test one room at a time before I invested in keypads or something?
Kor is offline
post #6 of 6 Old 05-09-2013, 09:23 AM
jautor's Avatar
Liked: 781
Are you concerned about the cables being damaged? You can easily test them for continuity, but it will be time-consuming. I wouldn't worry about it - but if you intend to buy a keypad-based solution, you can terminate both ends with an RJ45 and use a network cable tester to make sure all 8 wires are good.
Jeff
Reply Home A/V Distribution
