Help with old new home - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-13-2013, 10:59 PM - Thread Starter
bmw325cic's Avatar
Just bought a new home and it has 4 speakers in living room 2 in the front room with a knob style control 2 in master bedroom 2 on side porch 2 on front porch 2 on downstairs front porch but there are only 2 knobs so not sure what I need also there is 6 cat5e ports under the tv which goes to the media cabinet and all the speaker wires go there Aswell
bmw325cic is offline
post #2 of 11 Old 05-13-2013, 10:59 PM - Thread Starter
bmw325cic's Avatar
post #3 of 11 Old 05-13-2013, 11:00 PM - Thread Starter
bmw325cic's Avatar
Bedroom
post #4 of 11 Old 05-13-2013, 11:01 PM - Thread Starter
bmw325cic's Avatar
cheap speaker wire
post #5 of 11 Old 05-13-2013, 11:02 PM - Thread Starter
bmw325cic's Avatar
The cat 5 e into Media cab
post #6 of 11 Old 05-13-2013, 11:03 PM - Thread Starter
bmw325cic's Avatar
Speaker wire for center ?
post #7 of 11 Old 05-13-2013, 11:04 PM - Thread Starter
bmw325cic's Avatar
The cat 5 e into each room
post #8 of 11 Old 05-14-2013, 09:09 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Your description and pictures are hard to follow...
The patch panel in the closet would seem to be where an Ethernet switch or router was placed. Is there a power plug in that closet as well (seems to be one on the right edge of the picture).
The loose cat5e wires you're holding were at one point punched down - where do they all go?
You'll need to pull the volume control and see what speakers are attached to each one. I suspect all the outdoor speakers may be looped through one of those. The four living room speakers are likely intended to connect directly (no volume control). Use a 9V battery (or hook up a receiver) to tone out each pair of speaker wires, label them, and then you can post a diagram of the actual layout. Same for the cat5e wires - we need to know where both ends are...
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #9 of 11 Old 05-15-2013, 05:00 AM - Thread Starter
bmw325cic's Avatar
The cat five holding in my hand go underneath the tv there are six of them and in the closet that's where Comcast and u verse come into the house , the owner before I went bankrupt during construction that's why it was never finished all the wires go into a media cabinet with two racks but nothing else but a fan
post #10 of 11 Old 05-15-2013, 05:17 AM - Thread Starter
bmw325cic's Avatar
I am trying to figure out what the old homeowner was trying todo , there also are some starts to a lutron system but never finished Aswell , I have my local savant dealer coming out next week but the programming is what costs so damn much I have a lot of equipment from my last home the new owners said it was too complicated the only thing they keep was the whole home audio amp and savant docks
post #11 of 11 Old 05-15-2013, 06:49 AM
jautor's Avatar
Liked: 852
The six cat5e cables going from the TV location to the media closet rack were probably for HDMI-over-cat5e extenders plus anything else he wanted to do. There was probably equipment in the rack, including a cat5e patch panel, which were removed.
jautor is offline
Reply Home A/V Distribution
