7" Android Tablet Wall Mount hardware - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-18-2013, 11:07 AM - Thread Starter
CaptainChunk's Avatar
I'm going to be using this Coby 7" Android tablet as a media streamer and I need to find a way to securely mount it near my AV equipment. (http://www.amazon.com/Coby-7-Inch-Android-Internet-Tablet/dp/B00B2HCLL6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1368895822&sr=1-1) My mount location is overhead so ideally, I'd be able to angle it downward so I can see it when I select music. I'm not planning to use this for anything other than streaming music, so the mount doesn't need to provide easy access.
I've looked for a mount for a couple of days now, and haven't found anything. Everything is designed for a full size iPad. The closest I have found is from Peerless. http://www.amazon.com/dp/B0081XAWKG/?tag=googhydr-20&hvadid=25564344991&hvpos=1t2&hvexid=&hvnetw=g&hvrand=735670279555345963&hvpone=43.09&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_4au8uijd5f_b
I have my doubts that it will work for a 7" tablet. Do you know of anything similar to this that is designed for 7" tablets? Thanks for the help.
CaptainChunk is offline
post #2 of 4 Old 05-18-2013, 07:53 PM
AV_Integrated's Avatar
Quoted: 972 Post(s)
Liked: 718
May I make a suggestion?
Okay, just kidding. Unfortunately, I am not aware of good docks for this. Part of going Android is living with this type of issue. Get an iPad, you have a dozen choices, go with Android, and you have to cobble stuff together.
Not sure if you saw this option though...
http://www.crutchfield.com/p_837WALLWH/iOmounts-iOwall-White-powdercoat.html?tp=59554&awkw=54225539425&awat=pla&awnw=g&awcr=25048911145&awdv=c
Oh, and this page has some options:
http://padholdr.com/wall-mounted-ipad-and-tablet-holders/
Search for 'tablet wall mount' - and you will get from here to there I believe.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 4 Old 05-19-2013, 02:14 PM - Thread Starter
Thanks for the links. I hadn't seen that IOmount yet, so thanks for that. After looking around, I'll probably just get some small mount and use some strong velcro. That should be enough to hold it, I hope.
post #4 of 4 Old 05-20-2013, 08:55 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
There is a fellow over on Cocoontech who had a thread about his unique DIY mount
http://cocoontech.com/forums/topic/24508-my-affordable-removable-wall-touchscreen-solution/
The thread is a little wonky, but he linked to his build here
http://www.controlmypad.com/projects.html
NickTheGreat is offline
Reply Home A/V Distribution
