Best Cable Cutter Tool (Coax & Ethernet) - AVS Forum | Home Theater Discussions And Reviews
Old 06-01-2013, 12:12 AM - Thread Starter
Cipher's Avatar
I'm looking for some recommendations on the best tool to cut Coax and Ethernet cable. Also, the Ethernet cable I'm using is thick Cat6A (Belden 10GX line).
I currently own the following Klein cable cutter - http://www.amazon.com/Klein-J63050-Journeyman-High-Leverage-Cutter/dp/B00093GCK0
I've used it for a few cuts and it cuts easily, however it slightly compresses/squeezes the cut end of the cable. I'm not sure if this is normal or if there is a better tool for the job.
What do people in the fields use when cutting these types of cables all day long?
Cipher is offline
Old 06-01-2013, 12:34 AM
gregzoll's Avatar
Liked: 33
Wrong tool for the job. Those Dykes are made to cut electrical cable, not stuff like Coax or Low Voltage wiring. Something like these work better http://www.idealindustries.com/prodDetail.do?prodId=35-053&div=2&l1=tools&l2=cutters&l3=35-053 or these http://www.idealindustries.com/prodDetail.do?prodId=45-074&div=2&l1=tools&l2=cutters&l3=45-074
gregzoll is offline
Old 06-01-2013, 12:47 AM
Colm's Avatar
Liked: 94
The Klein 63028 might work better for you for the coax than the 63050. Frankly, any generic hand tool is going to deform the cut end of the cable a bit.
If you are worried about cable performance, don't sweat it. Yeah, impedance is a factor of geometry as well as dielectric constant. But as soon as you put a connector on the coax, it is going to fix the geometry problem. And you have to untwist the pairs of the Category 6a cable a bit to terminate it anyway.
Colm is offline
Old 06-01-2013, 03:14 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
When pulling the cables in my home, I use whatever is handy - often a lineman's pliers or diagonal cutter. I always cut the cable to the right length later, and as Colm said, adding the connector fixes the 'problem'. Pulling and trimming are often done on different days, for me.
If you're a pro, use expensive tools, and cut it to the right length once. Saves time and cable.
I use an EZRJ45 compression tool for category cable connectors which sacrifices about 2" of the cable end, eliminating the issue for cat cables. And yes, I'm aware it may introduce other issues, with the outside conductors.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 06-01-2013, 10:03 AM - Thread Starter
Cipher's Avatar
Thanks for the links, gregzoll. Unfortunately, it looks like the ratcheting cable cutter is out of my price range as it's over $200! However, the Data T-Cutter is affordable since it's under $20. Also, I found the following information from Ideal regarding the T-Cutter:
Cutting of coaxial cable requires the use of a shearing type or rounded blade cable cutter, like the IDEAL Data T®-Cutter (45-074). Cut the coaxial cable to the proper length needed for your application. Note: Diagonals or side-cutters will deform the cable and may affect the performance. However, if your coaxial cable has a center conductor made of steel, it is recommended you use a diagonal cutter.
Colm, thanks for the link to the Klein Coax cutter as I didn't even know they had one marketed directly like this.
Cipher is offline
Old 06-01-2013, 11:15 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
To hijack this thread, or take it to the next logical step.... what're the best tools to use for skinning the jacket on CAT5/6 to prep for installing the connectors?
wkearney99 is offline
Old 06-01-2013, 01:38 PM
acesat's Avatar
for coax there's nothing wrong with side cutters like these http://amzn.com/B00004SBDD since you'll be stripping the squashed dielectric off anyways. I use them for network cable too because you gotta snip off a little after you untwist or punch down. I know how giddy we can get from tools because tools are awesome. But you're not 'settling' by getting diagonal cutters, you're actually getting a good tool. And there are strippers that do category cable but otherwise you can just nick the end of the jacket and peel it back
acesat is offline
Old 06-01-2013, 02:55 PM
pirspilane's Avatar
I use the Paladin KT8 for coax. The cutting edges are keener than on dykes, so less deformation. They have concave cutting jaws that are approximately the same radius as coax. However, there is still some deformation, just less than with dykes. You can squish the dielectric back into shape with a pair of pliers, though.
pirspilane is offline
Old 06-01-2013, 04:47 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
As Colm wrote, you're cutting off the end of the cable anyway. What you use to cut it makes absolutely no difference in the post-termination performance of the cable.
CIAO!
Ed N.
egnlsn is offline
Old 06-01-2013, 06:07 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
VDV120-006_ICON_1.JPG?itok=SPKurU7H
I use this Klein radial stripper for cat cable jackets. In this pic, top left, small blade sticking up, within the rectangular notch, works well, no need for radial function.
Neurorad is offline
Old 06-01-2013, 07:44 PM
gregzoll's Avatar
Liked: 33
Same as any other company that makes that unit, they just change the name on the item, but same Chinese company makes them.
gregzoll is offline
Old 06-01-2013, 09:20 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I'm honestly unsure if mine is Klein or not, but it looks like that one. I did a GIS of yellow category cable jacket stripper, and I found the link to that Klein one.
That notched cutter works very well for category cable jackets. You just need to score the jacket a little bit, and then bend the cable back and forth a little at the score.
There is a neat trick I've seen on YouTube to use the separated jacket piece to help separate the twisted pairs.
Neurorad is offline
Old 06-02-2013, 08:01 AM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Something like this?
http://www.amazon.com/Klein-Tools-VDV100-801-SEN-Dual-Cartridge-Stripper
Seems like it'd be handy to be able to strip both coax and twisted pair with just one tool. I've got both the cans in the wiring closet AND the wall plates to deal with. One less tool to carry or dig out of the tool belt.
I've got some other brand coax stripper and it works but it's not so amazing as to rave about it.
Old 06-02-2013, 11:46 AM
Colm's Avatar
Liked: 94
Always have it with me.
Colm is offline
Old 06-02-2013, 09:38 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Is each cartridge adjustable, e.g. can 1 handle RG6 and RG6QS? I know it's not an issue for you, as you most probably have a single type.
Neurorad is offline
