HDMI over a single cat5 or cat6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-01-2013, 10:24 PM - Thread Starter
Rubics's Avatar
Does anyone know about a good product to distribute video from a pc, DVD player, security cameras, etc to all the devices in my house. I only have a single
Cat6 cable running behind the walls. Is there such a product?
Rubics is offline
post #2 of 11 Old 06-02-2013, 11:43 AM
skicrave's Avatar
HDBaseT Matrix from a number of vendors is what you want to do that, albeit be aware of the caveats of such a system.
skicrave is offline
post #3 of 11 Old 06-03-2013, 12:28 PM
octava's Avatar
A HDbaseT Video Matrix is what you are looking for.
The matrix will allow you to distribute/switch any 4 video sources to 8 Displays over 1 CAT6 cable
This is how you would connect it :
octava is offline
post #4 of 11 Old 06-03-2013, 12:36 PM
AV_Integrated's Avatar
Quoted: 971 Post(s)
Liked: 718
You can also use HD-Base-T baluns at each end and use standard HDMI matrix switchers to the size you need.
Keep in mind, you will not be using the Cat-6 into a Ethernet switch anymore and the Cat-6 must be run directly to where the matrix is located. This is not a 'networked' solution, but there are HD-Base-T products which will allow you to send Ethernet along with the HDMI video to any location.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #5 of 11 Old 06-03-2013, 09:54 PM - Thread Starter
Rubics's Avatar
What caveats are these? I have been checking these HDBaseT Matrix and seem over my budget ($1500+). I know HDMI is the normal nowadays but are there other systems of getting good quality video (720p would be enough for me) without using HDMI? Maybe component video, DVI or even VGI?
Rubics is offline
post #6 of 11 Old 06-03-2013, 10:08 PM - Thread Starter
Rubics's Avatar
Do you mean I have to run the cat6 cables straight to the matrix? All my cat6 cables end in a Leviton structure wire box (by the way rated cat5e) in my closet. Can I use patch cables to connect to the matrix?
Rubics is offline
post #7 of 11 Old 06-03-2013, 11:43 PM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
If your sources have component video outputs, there is little downside to component vs. HDMI when it comes to matrix switch "real world" performance. The issues with HDMI matrix products is really the fault of HDMI, not the matrix. Since the source and the display (TV) talk to each other to determine compatibility, the source will downgrade its output to meet the common denominator capabilities of all attached displays. Which likely means that audio will be limited to 2-channel PCM stereo.
Component video and either digital audio OR analog stereo can be sent over a single cat5e/cat6 using a number of balun products. Component matrix switches are cheap (and available used readily as folks "upgrade" to HDMI).
Yes, you can use patch cables. His point was that the wiring is used in a completely different manner than Ethernet networking - the two have nothing in common except they use the same type of wire. You'll need to locate your sources and the matrix switch near your Leviton box, most likely...
Jeff
jautor is offline
post #8 of 11 Old 06-04-2013, 10:00 AM
Quoted: 971 Post(s)
Liked: 718
As stated, you may use patch cables to take them to your matrix as necessary. These are no longer going to be Ethernet cables at all, but will be used exclusively, and solely as HD-Base-T cables.
Your other options are to use component video baluns and take audio/video over the cat cables to various rooms and pick up a component video matrix switch. The component video 8x8 matrix can be had for under $300 on eBay and represents a remarkable value for your money, but will limit you in many ways in terms of quality and since it will be analog, it will be far more susceptible to noise and interference.
Search on eBay for "Extron Crosspoint" to find some solid analog A/V matrix switchers.
Yes, HD-Base-T is expensive right now, and likely will remain expensive for years to come as the technology continues to progress and change.
post #9 of 11 Old 06-05-2013, 01:04 AM - Thread Starter
Rubics's Avatar
Rubics is offline
post #10 of 11 Old 06-05-2013, 06:19 AM
Joe Fernand's Avatar
Quoted: 280 Post(s)
Liked: 164
There is as much chance of it working as it not working!
HDMI can be a complex beast to tame – especially when you start distributing multiple Sources to multiple Zones!
How many Source devices?
How many Zones?
How do you plan to control your kit from the various Zones?
Most modern AV devices are constantly being updated with online or over-the-air Firmware updates – if your HDMI gear lacks the ability to also be updated via USB or LAN you can quickly find your HDMI ‘Hub’ running into compatibility issues!
Your budget is very tight for a fully ‘integrated’ single CAT solution with all of the useful features a decent quality HDMI Matrix will include – one of which is invariably a decent level of online and telephone Tech support from your supplier!
Joe
AV_Integrated likes this.
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #11 of 11 Old 06-05-2013, 09:49 AM
Quoted: 971 Post(s)
Liked: 718
I'm just going to agree with Joe on this one. I've used the Monoprice 4x4 HDMI Matrix and it was terrible. The displays all blank during switching, and many times it would not properly show sources. It was a complete headache and I pulled it out in favor of going with a component video matrix switcher which has been unstoppably reliable.
I'm not sure what 'cheaper' product is out there which does non-blanking HDMI switching. I generally refer to the Gefen Toolbox 8x8 HDMI matrix which is a bit under $2,000, then pair it with Monoprice HD-Base-T extenders at about $190 per unit.
Not exactly inexpensive, but I would expect a far higher level of reliability out of these types of products than I have personally seen from my Monoprice 4x4 HDMI matrix.
In the next few weeks I'm getting a demo 8x8 Gefen unit in so I can do some testing and I will let others know how well it works (or not).
Reply Home A/V Distribution
Cat5 Rack 1u
