Cat6 and hdmi question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-03-2013, 07:26 AM - Thread Starter
chan-man's Avatar
I'm new at all this so can somebody post a link for cat6 cable that would be great for both LAN network and HDMI over cat6? thanks I appreciate it.
chan-man is offline
post #2 of 11 Old 06-03-2013, 07:42 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 781
Any cat6 cable is fine. The only difference is if the wire is solid or stranded. Use solid wire if you're going to run wire to keystone jacks or punch down blocks. If you're just using a terminated patch cable, that will be stranded (so it's more flexible).
jautor is online now
post #3 of 11 Old 06-03-2013, 08:43 AM
canuck_fr's Avatar
I have had some issues in the past when doing HDMI over Cat 6 cable because one wire is longer than the others in Cat 6 cables. I have had better luck with Cat 5 or Cat 5e.
canuck_fr is offline
post #4 of 11 Old 06-03-2013, 10:32 AM
AV_Integrated's Avatar
Quoted: 990 Post(s)
Liked: 728
It typically depends on the HDMI over Cat extenders you are using, not the cable. Cat-5 also has skew in the cables which any quality extender can deal with. But, with the current crop of HD-Base-T extenders, there is no issues with skew in the cables that I have seen and they are designed from the ground up to work with standard skewed cat cabling.
I wouldn't put any blame on the cables in use.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #5 of 11 Old 06-03-2013, 11:23 AM - Thread Starter
chan-man's Avatar
chan-man is offline
post #6 of 11 Old 06-03-2013, 12:14 PM
octava's Avatar
The specifications you should look for in a CAT 6 cable for Ethernet and also can be used for HD video distribution are:
- CAT6a- a shielded twisted pair cable.
The outer shielding provides some immunity from extraneous noise
- Look for a wire gauge that is 24AWG or better. The thicker in general will be better
- TIA-568-B. Most are B, but just double check. This spficifies the specific crossings of one of the pairs
- Also for HD video, you want to avoid running the cables thru extraneous wall plates, couplers and terminal jacks.
It is fine for 10/100mbps ethernet data but not recommended for HD video distribution.
- Also avoid running the cables in loops. Make it straight as possible.
Here is some info on CAT cable recommendations
octava is offline
post #7 of 11 Old 06-03-2013, 12:34 PM
Quoted: 990 Post(s)
Liked: 728
I have not used those specific models, but neither of them is using HD-Base-T and my experience that I have had with Monoprice double cat-x extenders is that they are weak to terrible in terms of performance. Despite the claims, on repeated attempts with multiple adapters from them, I never was able to get 1080p to transmit to my Samsung display or my projector using several of their HDMI extenders.
Finally I put up the cash and got their HD-Base-T extender which uses a single Cat-5/6 cable, and it worked flawlessly the first time and every single time since then.
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011012&p_id=8122&seq=1&format=2
This product is certainly more expensive, but unlike the other products, this one actually works, and works really well.
post #8 of 11 Old 06-03-2013, 01:53 PM - Thread Starter
chan-man's Avatar
Is that HD-base-t good for 2 hdmi cables since it comes with 2 or does one have to go in the media closet and one behind the tv?
chan-man is offline
post #9 of 11 Old 06-03-2013, 05:02 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
All catX based hdmi extenders use two baluns. One at the transmitting end, and one at the receiveing end.
ifor is offline
post #10 of 11 Old 06-03-2013, 05:10 PM - Thread Starter
chan-man's Avatar
chan-man is offline
post #11 of 11 Old 06-03-2013, 07:53 PM
jautor's Avatar
Liked: 781
Originally Posted by chan-man View Post
Ok thanks do think this is the type cat6 I need to use? http://www.monoprice.com/mobile/Product/Details/8106?mainCategoryId=102&categoryId=10234&subCategoryId=1023401
Yes.
Reply Home A/V Distribution
