i want SONOS but still Need FM - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-06-2013, 04:10 AM - Thread Starter
gumati's Avatar
i have 5 Zones 4 in-ceiling speakers and 1 outdoor speakers
all wires goes to equipment room i was about to install sonos but i still need FM stations
is there way to add fm radio to sonons and be able to change stations from iphone or any smart phone
also is there audio distribution system with FM tuner ??
any ideas
Living Room : Samsung UN65F8000 - PS3 - WD LIVE- Emtovia in-ceiling Speakers - SONOS CONNECT:AMP
HT :Sony HW55ES - Elite Screen 150" - Pioneer VSX-1120-K-Emotiva XPA-5 - PS4 - Med600X3D - Emtovia in-ceiling Speakers
RF-7 II Floorstanding
RC-64 II Center Channel
RS-62 II Surround
SW-115 Subwoofer
gumati is offline
post #2 of 12 Old 06-06-2013, 04:29 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Sonos, and other music servers, use the online service RadioTime to provide most FM stations to the player. So, no tuner is usually required.
http://forums.sonos.com/tags.php?tag=radiotime
You can sign up to RadioTime on a PC and stream FM for a few days, to see if it meets your needs, before buying anything.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 12 Old 06-06-2013, 04:59 AM - Thread Starter
gumati's Avatar
in my county most of radio stations they don't stream online that's why
RS-62 II Surround
SW-115 Subwoofer
gumati is offline
post #4 of 12 Old 06-06-2013, 07:36 AM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
In that case, the Sonos Connect / Amp units have an analog audio input, so you can attach an FM tuner to one of them, and it will be available to any Sonos zone. No remote control of the tuner, however.
(and put your location in your forum profile, as you'll get better "local" advice if we know where you are)
jautor is offline
post #5 of 12 Old 06-06-2013, 09:10 AM - Thread Starter
gumati's Avatar
i found NV-T2FAM Dual AM/FM Tuner seems do the job
RS-62 II Surround
SW-115 Subwoofer
gumati is offline
post #6 of 12 Old 06-06-2013, 09:27 AM
jautor's Avatar
Liked: 777
As an input to a Sonos unit, yes, it will do - I would expect there are less-expensive FM tuners (any stereo receiver could do the job) than the NuVo piece if you're not going to use a NuVo system...
jautor is offline
post #7 of 12 Old 06-06-2013, 01:43 PM - Thread Starter
gumati's Avatar
yes you right just got quoted with 495$ and they said For use with Essentia, Grand Concerto and
Renovia Systems
RS-62 II Surround
SW-115 Subwoofer
gumati is offline
post #8 of 12 Old 06-06-2013, 02:40 PM
jautor's Avatar
Liked: 777
yes you right just got quoted with 495$ and they said For use with Essentia, Grand Concerto and Renovia Systems
Yep, you'd be paying for a lot of functionality that you won't be using.
Also, FM tuners should be readily available on the used market. There have been a number of good tuners over the years from audio companies. Is there an "eBay Local" site for Libya?
jautor is offline
post #9 of 12 Old 06-06-2013, 03:15 PM - Thread Starter
gumati's Avatar
there is no ebay local site also paypal wont accept libyan credit card
i think i will use A/V receiver
RS-62 II Surround
SW-115 Subwoofer
gumati is offline
post #10 of 12 Old 08-10-2014, 06:53 PM
dbpaddler's Avatar
A built in tuner would be nice for one reason, sports. You can't listen to games via the online version of the broadcasting radio station. I end up using a a small mp3 player, but that's just Fm. And I have to remember to turn it on/off. Some games are AM so that idea is limited. And I'm not buying a connect to plug into my receiver just for radio.
So the idea of having an actual tuner built in isn't so far fetched.
dbpaddler is offline
post #11 of 12 Old 08-10-2014, 07:50 PM
uriah's Avatar
Quoted: 24 Post(s)
Originally Posted by necessitfo View Post
yeah, the Sonos Connect / Amp units have an analog audio input, so you can attach an FM tuner to one of them, and it will be available to any Sonos zone. No remote control of the tuner,[IMG]http://*******/OSI1pM[/IMG]thank you
If remote is very important to you there are receivers with pre outs that can be controlled by I phone etc.
uriah is offline
post #12 of 12 Old 08-10-2014, 10:22 PM
jautor's Avatar
Liked: 777
I'd hope in the year since the last post he's found a workable solution...
jautor is offline
Reply Home A/V Distribution
