Intercom over CAT5? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-08-2013, 06:55 AM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
Is it possible to have some sort of intercom system over CAT5 cabling and does it need to be separate from the lines used for the internet? Would like to setup an intercom to 4 rooms that are pre-wires with CAT5. Only other option would be some sort of wireless system I'm guessing?
HX_Guy is offline
post #2 of 4 Old 06-08-2013, 03:49 PM
Colm's Avatar
Liked: 94
Originally Posted by HX_Guy View Post
Is it possible to have some sort of intercom system over CAT5 cabling...
Yes, there are products available for that.
...does it need to be separate from the lines used for the internet?
Yes, AFAIK.
Colm is offline
post #3 of 4 Old 06-08-2013, 06:45 PM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Most intercoms connect to each other using category cable. Some use the LAN to communicate (IP intercoms), and some do not.
Not everything using category cable is on a LAN. It's a multipurpose cable.
Google 'IP intercom' if you want them to communicate with each other over your home network. Google 'intercom' if you do not.
OnQ makes some nice looking intercoms that connect to each other with category cable, but are not networked on the home LAN.
If you have category cables run to your intercom locations, you can use either IP or non-IP intercoms, since both (usually) use category cable.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 4 Old 06-08-2013, 07:40 PM
Colm's Avatar
Liked: 94
Originally Posted by Neurorad View Post
...IP intercoms...
Doh!
Colm is offline
Reply Home A/V Distribution
Cat5 Rack 1u
