Wiring a Hardwire Box for Surface Lighting. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-13-2013, 08:41 AM - Thread Starter
mijotter's Avatar
Liked: 59
Would anyone know if this hardwire box: http://www.menards.com/main/lighting-fans/indoor-lights/accent-lights/hardwire-junction-box-black/p-1656071-c-6349.htm has a load, line, and neutral wire for wiring to an Insteon light switch? I tried going to the manufacturers website and it doesn't exist.
mijotter is offline
post #2 of 5 Old 06-13-2013, 04:57 PM
AV_Integrated's Avatar
Quoted: 1105 Post(s)
Liked: 803
As far as I can tell that's just a surface mount junction box - which means it doesn't have any wires in it. You provide the wires which would be in it. It basically just looks like a rocker on/off switch. Not sure what/where this would be used.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 5 Old 06-13-2013, 10:55 PM - Thread Starter
mijotter's Avatar
Liked: 59
It actually has a black and white wire coming from it with a green wire that comes with the package, sorry I should have mentioned that in my original post. I just have no clue when it comes to this stuff what that means.
mijotter is offline
post #4 of 5 Old 06-14-2013, 07:20 AM
olyteddy's Avatar
Quoted: 534 Post(s)
Liked: 940
well, from your link:
1. Consult a licensed electrician if you are not sure about the installation!!!
but yeah, it converts an in the wall wire to the little 3 wire plug(s) used by some under counter lights.
This might help: http://www.menards.com/main/store/20090519001/items/media/Electrical/american_lighting_patriot/Install_Instruct/Hardwire_Junction_Box_instructions_warranty.pdf
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #5 of 5 Old 06-14-2013, 07:47 AM
Liked: 803
If that box is a surface mount switched 2-wire to standard Edison plug adapter, then it is fine.
You would use a plug-in type Insteon product with it.
The LINE and NEUTRAL (along with ground) come out of the wall, into that box. An electrical load are the lights themselves.
So the hot wire (black) coming out of the wall is 'line'
The neutral wire (white) coming out of the wall is there.
The load wire is the black wire which runs to your actual lights. That is the one which gets dimmed.
It all depends on what you are trying to dim and which Insteon piece you are intending to utilize with this.
Reply Home A/V Distribution
