HDMI switch/hub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-16-2013, 07:17 AM - Thread Starter
mreber's Avatar
Looking for recommendations for a HDMI switch/hub. Have the masscool switch, and it's a piece of junk. TV will randomly cut out for a second multiple times a day. Do any of these work? Don't want to spend the money on some super high-end product. Just need something with at least 3 inputs and one output.
mreber is offline
post #2 of 7 Old 06-16-2013, 10:59 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
I googled masscool switch and on paper it should work, I think the best thing maybe returning it for a deferent one. If you don't get Masscool to replace it try Monoprice.com. I have used a lot of their product without a complaint of any kind.
Phil17108 is offline
post #3 of 7 Old 06-16-2013, 12:31 PM - Thread Starter
mreber's Avatar
The masscool has a lot of great reviews, but there are definitely people with similar complaints as me. It has an auto switch feature. Not sure if the blueray being in standby screws it up. What's weird is if I unplug the blueray, it stops working all together. Cable is still connected.
mreber is offline
post #4 of 7 Old 06-17-2013, 07:03 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
"What's weird is if I unplug the blueray, it stops working all together. Cable is still connected"
Went back for another look at it and found this.
External Power Supply: No power needed for standard product.
That is the problem. There is something called CEC and deferent manufactures have deferent names for it, that can mess with self powered switches. Unplugging the Blu-Ray removes power from switch. If you can get into the menu of the AVR, TV, Blu-Ray and turn that off. If that does not work, bet it won't, return it and get one that uses an external power supply. Monoprice.com have ones that do.
post #5 of 7 Old 06-17-2013, 12:45 PM
Joe Fernand's Avatar
Quoted: 288 Post(s)
Liked: 168
Of course it requires power and it looks like it is trying to 'steal' it from your BD player.
Always best to use a Switch with an External PSU - http://www.octavainc.com/HDMI%20switch%203port.htm
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
post #6 of 7 Old 06-17-2013, 01:32 PM - Thread Starter
mreber's Avatar
Thanks guys. It didn't come with a power supply. It takes 5 volts DC. Looking at all of the power supplies I've accumulated through the years, I have one that fits the connector and puts out 4.8 volts DC. I'm assuming that's close enough? Output voltage is going to vary a little bit anyway, right? I can't image I'll harm anything if I plug the 4.8 VDC into something that should be getting 5 VDC.
mreber is offline
post #7 of 7 Old 06-17-2013, 06:44 PM - Thread Starter
mreber's Avatar
Actually the adapter output is 5.8 volts. I'm thinking that may be pushing it.
mreber is offline
Reply Home A/V Distribution
