Problem with DVD player over Cat6 - AVS Forum | Home Theater Discussions And Reviews
Old 06-16-2013, 09:17 AM - Thread Starter
hvtopiwala's Avatar
i have the entire house distributed with CAT6 cables to each bedroom to the media cabinet using the following wall plates: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10425&cs_id=1042501&p_id=8200&seq=1&format=2
i have verizon boxes hooked up to all of them and everything works fine. i recently got a DVD player and its not working on my long runs (50ft runs). it works on my short runs though (25ft). i thought it was lack of power so i got some power adapters and put it on the wall plates and still, didnt work. any ideas whats going on? obviously the wall plates work cuz the cable boxes work on them...cant figure it out!
hvtopiwala is offline
Old 06-17-2013, 07:44 AM - Thread Starter
hvtopiwala's Avatar
anyone?
Old 06-17-2013, 08:19 AM
jautor's Avatar
Quoted: 1225 Post(s)
Liked: 787
The inexpensive HDMI extenders are hit-and-miss... I assume the DVD player (not a BD) is probably upconverting? You might try setting it to 480p output and letting the TV do that work, that might help with the distance. I'm guessing the Verizon box is only sending 1080i max, so if the DVD player is sending 1080p, that could explain the difference.
jautor is offline
Old 06-17-2013, 08:32 AM - Thread Starter
hvtopiwala's Avatar
its a bluray player actually, yeah the verizon is sending 1080i...this is the one i bought: http://www.bestbuy.com/site/Smart+Wi-Fi+Built-In+Blu-ray+Player/8053048.p?id=1218863730154&skuId=8053048&st=bluray%20player&cp=1&lp=2
Old 06-17-2013, 09:57 AM
jautor's Avatar
Liked: 787
Set the BD player output to 1080i max and see what happens. Note that for most BD content, and if your TV does the assembly correctly, you won't see any PQ difference...
jautor is offline
Old 06-17-2013, 12:49 PM
AV_Integrated's Avatar
Quoted: 999 Post(s)
Liked: 730
I have never had much luck with the cheap Monoprice HDMI extenders and resolutions above 1080i video. Forget their claims, they just can't handle it. Their HD-Base-T extenders (about $200) are phenomenal, but their wallplate versions and cheap dual cat-5 solutions just don't work in my experience.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
