Combination of CAT6 cable and TF wire. - AVS Forum | Home Theater Discussions And Reviews
Old 06-27-2013, 08:53 PM - Thread Starter
Joseph Paranas's Avatar
Good day Sir,
Is it allowed to combine the CAT6 cable (for Break Glass & Electromagnetic Lock) and TF wire (for Card Reader) in the same conduit or raceway though it is the same system (Access Control System)? What will be the effect?
Thank you and God bless.
Joseph Paranas is offline
Old 06-28-2013, 09:19 AM
DGF
DGF's Avatar
Liked: 39
Both are low voltage, so you are good to go!
A primary consideration with running different types of wires comes from mixing 110/240v with non-mains voltage wiring - which you're not doing.
Dave
DGF is offline
Old 06-30-2013, 10:59 PM - Thread Starter
Thanks sir Dave and have a blessed day.
