Combination Audio/Visual receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-04-2013, 02:14 PM - Thread Starter
killswitch1968's Avatar
I have wired my house x 2 Cat5/x2 Cat6, + x1 RG59 to 5 different room locations for video. Two of these rooms also have dual channel speakers for whole home audio.
Since I need a matrix to distribute the video anyway, are there systems that can distribute both video & audio, and be used as a multizone audio system for music?
Are there any systems that would utilize the existing Cat6 cables without needing baluns?
killswitch1968 is offline
post #2 of 4 Old 07-05-2013, 08:46 AM
jautor's Avatar
Quoted: 1228 Post(s)
Liked: 788
Short answer is not anything that would be considered DIY or "budget". Those systems are much cheaper if installed separately, but they can certainly share sources. The remote / control methods are very different, too.
killswitch1968 likes this.
jautor is online now
post #3 of 4 Old 07-05-2013, 09:19 AM
Virtus's Avatar
In the rooms with whole home audio, are your TVs connected to the whole house audio speakers? If they were you could use something like a roku or apple tv to stream your music.
Virtus is offline
post #4 of 4 Old 07-05-2013, 11:22 AM - Thread Starter
Thanks Jautor, it did seem quite a bit more complicated than your basic matrix or 6/6 zone audio system.
And no Virtus, the speakers are home runned.
Reply Home A/V Distribution
