Ready to do the 5.1 + whole-home audio...help please. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 09-24-2013, 10:04 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Originally Posted by jkust View Post
And you can buy volume control knobs that start the volume at zero so instead of turning a volume control down in each room if you left the volume up...you need to turn the volume up in each room to get sound.
Can you point to one that doesn't require additional wiring (power)? I assume that function will require something... It would certainly be a benefit, though, if those can be used - and if they don't cost in total as much as a WHA system would have to begin with! biggrin.gif
jautor is online now
post #32 of 32 Old 09-24-2013, 10:49 AM
jkust's Avatar
Quoted: 21 Post(s)
I ran across them when I was doing my WHA project...I can't recall which site but pretty sure it wasn't Monoprice. They were a good bit more than the ones I got at monorprice so I didn't really investigate. Like $40 instead of $20 or something around there. I can see mixing and matching depending on the room now in hindsight.
jkust is offline
Reply Home A/V Distribution
