Looking for A/V component with these dimensions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-08-2013, 09:46 AM - Thread Starter
ktrdsl23's Avatar
I have a cheap security DVR in my middle atlantic rack without a proper sized face plate. Since it is cheap I don't feel like sending it in to Middle Atlantic to be measured and was wondering if anybody knew a good way to find a different component with these dimensions that MA might already have a face plate for. The DVR is 12.5" wide x 2.5" tall. I realize if I can find on it won't look perfect but it will look better than the way it currently does (open face). If anybody knows of a device or a good way to figure this out I'd appreciate it.
ktrdsl23 is offline
post #2 of 6 Old 07-08-2013, 09:55 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Local place might cut up a blank plate for you - metal CNC/laser cutting/fabrication shop. I'll ask a buddy in Chicago for a rec.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 6 Old 07-08-2013, 10:55 AM
AV_Integrated's Avatar
Quoted: 983 Post(s)
Liked: 725
If you call Middle Atlantic, they will send you a form which you can fill out and send to them and they will make a plate to the dimensions that you write down. They take no liability at all if you mess it up, but they will do this.
I have done this in the past with a Gefen piece I needed done and they did a very good job. They don't round corners or anything like that, but they got the height, width, and offset correct.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #4 of 6 Old 07-08-2013, 12:41 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
TonyNo from Cocoontech.com forums suggests Westmont Metal Manufacturing http://www.westmontmetal.com/, for a local shop to try.
Neurorad is offline
post #5 of 6 Old 07-08-2013, 05:20 PM - Thread Starter
ktrdsl23's Avatar
I'm not a dealer, do you know if they will do this for general customers?
ktrdsl23 is offline
post #6 of 6 Old 07-08-2013, 07:24 PM
Quoted: 983 Post(s)
Liked: 725
If they won't talk to you, shoot me a message and I will get you the form.
Reply Home A/V Distribution
