HD webcam over USB Balun - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-09-2013, 12:16 PM - Thread Starter
FLTech's Avatar
Quoted: 16 Post(s)
Does anyone know of a way to extend a USB HD webcam over 60ft?
I am using a Microsoft Lifecam Studio with 720p streaming. I have tried different brands of usb over single cat5 baluns with no success. the first issue was my fault because I wasn't buying baluns that were rated for the full 480MBPS that usb 2.0 supports.
So I then bought one from a military component website that was rated for 480MBPS and still nothing.
Trying to use this in a conference room for skype where the PC is located about 30ft from where the camera needs to be, which would require about a 50 ft run of cat5. all the baluns I tried were active btw, all had power adapter.
FLTech is offline
post #2 of 3 Old 07-09-2013, 02:39 PM
scl23enn4m3's Avatar
Have you considered using an active USB extension? I know the Kinect has a similar issue to this and would only work with baluns that were a few hundred dollars in cost or an active USB cable.
scl23enn4m3 is offline
post #3 of 3 Old 07-11-2013, 11:09 AM - Thread Starter
FLTech's Avatar
Quoted: 16 Post(s)
Yes I tried a 30' active male-female ext cable.
FLTech is offline
Reply Home A/V Distribution
